Hi,
first of all I would like to introduce myself here. I am a hobby boat builder since 2016, live in the Ruhr area in Germany and am the friend mentioned above by Günter (and proud to be called so). Pardon my English right at the beginning, but I am more used to reading English than writing. Additionally, I ask for your consideration if I get mixed up in places when converting the units of meters.
Since 2018 I have been building the 18 foot boat mentioned above, but I don't want to name the designer, because the plans are a bit meagre compared to the price, but I don't want to make my debut here with a designer bashing.
But I think the designer didn't put much brain power into the plans.
To give you some marginal data: the frames have a thickness of 2'' x 3'' and a distance of 10", the beam is 6' 8''m LOA is 18' and LWL 16'8''. It will be powered by a 6 HP outborder, the plans demand for a 7 HP 1 cylinder inbord diesel engin.
The "planed" planking is 1/2'' for the topside and 1'' plywood for the bottom (the boat is a single chine construction). The chine and sheer were build with laminated fir 1 1/4'' x 2 1/4'' (6 layers) and the inner keel is 1 1/4'' x 4'' (also laminated instead of solid wood of the same dimensions and type of wood)
The boat will be trailered if necessary, at most it will be in the water for 2 weeks at a stretch during the holidays.
As Günter already mentioned my space is limited, the shelter has 13' x 26' and is located in my garden. The storage in the living room mentioned by bajansailor is out of the question, not because of my wife (who I have chased to hell) but because of my cramped living situation with about 650 sq.ft. for me and my son (16 years old).
Gonzo's idea to cut the plywood in one day according to the templates is certainly good, but fails again because I have to store the cut parts temporarily. It would be difficult to store the plywood upright in the tent, because the tent protects the building site against the weather, but is not stable enough to hold the 12 panels 1/4'' that are required when standing upright with a slight inclination. An immediate processing of the cutouts and planking of the boat is not possible due to time reasons, I have to work in between.
Günter's fears were that, as described above, water could penetrate into the wood and by the swelling of the wood could break the bonds with epoxy putty (epoxy with cotton flocks).
According to my information (Georg Buehler), laminates made of solid wood should not be used with wood thicknesses over 2''. I had planned the floor planks in 10/16'' cross planking and the side planks in 1'' simply planked with fir. Afterwards the wood should be completely covered inside and outside with glass fibre laminate.
I didn't know the link to selway-fischer yet, but I had imagined the whole thing as in picture 3 and 7.
I'm not afraid of more work, it's not the question if I need more epoxy, but rather if I can finish the boat at all.
So far a "little" of information, which might describe the situation in more detail.
Cheers
Mio
