Planing hull kayaks??
Discussion in 'Boat Design' started by river runner, Nov 5, 2011.
  1. river runner
    Likes: 6, Points: 0, Legacy Rep: 91
    river runner baker
    I've seen magazine ads for white water kayaks with flattish bottoms that seemed to be implying that they were planing hulls. I've always assumed that you needed far more horsepower, than a human with a paddle could provide, to get up on a plane.
    I'm assuming this is just marketing BS. You can't really get a kayak up on a plane can you?
  2. Easy Rider
    Easy Rider Senior Member
    If you're surfing or sitting on the face of a standing wave you can. Some of that white water stuff gets a bit crazy.
  3. river runner
    river runner baker
    That's it! I feel like an idiot.
  4. jehardiman
    Likes: 503, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Yep, surf kayaks can get pretty funny looking.
  5. cyclops2
    Likes: 8, Points: 0, Legacy Rep: 94
    cyclops2 Senior Member
    Which has more drag area ?
    A flat bottom or a V bottom ?
    Flat has less, at Kayak speeds in near still water.
  6. Dirteater
    Likes: 22, Points: 0, Legacy Rep: 300
    Dirteater Senior Member
    there a gentleman who surfs behind the paddle-wheel boat near
    where I live (in his kayak). He's amazingly good at. it something to see for sure.
  7. waikikin
    waikikin Senior Member
  8. cyclops2
    Sporting
    With a life jacket on. I do it with a Lowe 16' X 15" high transom Aluminum fish boat & a 9.9 hp. Risky
    Dive. Dive :p
  9. river runner
    river runner baker
    Are you talking about wetted surface area? I thought flat had the most of any design, round the least, and V-bottom would be somewhere in between?
  10. cyclops2
    I know of no Kayakers near me who can get their SLIGHTLY V hulls on plane by paddleing. I have seen 1 ex Marine dam near get a 10' stripped down cheapy Aluminum fish boat on plane in calm water. The last 7' bottom of the boat is flat. His oars are as long as mine. 6 1/2' each.
    If a kayaker had 13' paddle & a Marine. Who knows ? Maybe the V would win.
    All the easiest planing boats I have seen are mini flat bottomed 3 point racing hydros or flat bottomed New Jersey racing Garveys.
  11. river runner
    river runner baker
    Yes, I understand that a flat bottom is more likely to plane than a V-bottom, but it sounded like you (cyclops2) were saying that a flat bottom had less drag/wetted surface, at normal kayak speeds, than a V-bottom, which is contrary to what I undestrand to be true. I'm still a bit skeptical that anyone can get anything up on a real plane from just oar or paddle power. If they could, seems like olypic rowers would switch to wide, flat bottom boats.
  12. cyclops2
    When rowing usually blindly.
    If your back is to the foward direction.
    A flat bottom is very erratic in the direction it will travel in. Loads of constant pulling corrections are needed.
    Long & skinney hulls do save a ton of energy during a race by going straighter with less corrections.
    2 equal athletes. The one in the skinny boat always wins.
  13. cyclops2
    As a thought.
    In slow moving efficient sailplanes.
    Is a wide wing more efficient ? Or a narrow but very long, front to the rear end of the wing.
  14. portacruise
    Likes: 65, Points: 48, Legacy Rep: 218
    portacruise Senior Member
    Two situations which are not kayaks, but might be planing under HP besides hydrofoils.
    What goes on with surfboards? Seems like they are sometimes planing while under human propulsion.
    What about skipboards, the flat disks you throw like a skipping rock and hop on in shallow water for a free glide ride? This might be some kind of shallow bottom effect though.
    Porta
  15. DCockey
    DCockey Senior Member
    Another reason, perhaps the more significant reason, that a longer, narrow hull does better in a rowing/sculling/paddling race is the wave drag will be less. That's assuming the length isn't so long that the increase in wetted surface area and correspond viscous drag increase doesn't offset the reduced wave drag.
