yes, it is a revolution
One of the most interesting developments about to be unveiled is the new foiler or foilers from Andrew McDougall(AMAC)-designer of the Bladerider and Mach II Moths. The main characteristic of this boat, as I understand it, will be ease of sailing. When he releases more information it will be available here-you can count on it. He is the most widely known individual foiler designer to speak to the need for an easy to sail foiler to allow people to get into foiling without the hassle involved in some of the high performance boats-I'm looking forward to his ideas.
Since the Peoples Foiler concept was first conceived by me years ago there has been lots of foiler development-mostly in the Moth class but also:
1) Mirabaud the largest 2 foil monofoiler currently sailing-about as fast as a Moth according to Thomas Jundt-the developer.
2) R Class foiler-the second 2 person bi-foiler ever developed in history,
3) and more: see New High Performance Monofoilers
My conception of a Peoples Foiler follows but it is critical to note that the people will define what actually becomes a "Peoples Foiler" not me but I suspect that the NUMBER ONE ingredient will be the sheer unadulterated fun of flying! Speed is not critical-ease of sailing and fun are the priority.
Some Potential Characteristics of a Peoples Foiler 2010:
1) Category One-Full Flying
a- I have always conceived of a Peoples Foiler as an easy to sail monohull foiler using just two hydrofoils because of the simplicity of such an arrangement.
b-the boat should probably be capable of sailing well with a 200-220lb single crew and be designed, perhaps, to use a form of weight equalization-allowing a wide crew range from perhaps 120lb-220lb, if possible-or "lightweight" and "heavyweight" versions. And/ or, a two person boat that could also be foiled singlehandedly.
c-beach sailable: must have retractable foils and excellent sea hugging stability-with buoyancy pods.
d-reefable rig, perhaps similar to the High Performance RS600FF, easy to do.
e-foiling characteristics:
---1- takes off in 5 knot wind-many areas of the world are very light air most of the time-it is critical to be able to foil in those conditions.
---2- excellent pitch characteristics-no crashes. Foils could be designed to have designed in/removable spoilers that allow light air takeoff with reduced top speed and reduced sensitivity to altitude control issues. A partial/full manual control system may not only be fun to sail with-it could be designed and developed to be sailed manually or automatically or a combination of both. Use could be made of variations of the Howes foil for the ultimate in two foil altitude control simplicity.
---3- low and /or variable altitude settings.
f- Emphasis on extreme crew comfort with the possible use of lightweight sliding bench seats to make it easy and fast to move side to side.
2) Category 2-Foil Assist
a- there are already boats like the I-14 , National 12 , Paul Riccelli's RYD14.6 and probably others using one form of "foil assist"-a rudder t-foil or similar type foil. But this is a huge untapped area of monohull design where the gains are potentially increased performance and better handling with minimum sized foils . The foils don't lift the boat clear of the water but do reduce the wetted surface of the hull and can enhance pitch performance and handling upwind and downwind .
Lots more potential for development here in all sizes of boat.
See pictures below of Jo Richards National 12 using a t-foil rudder AND a trim tab on the daggerboard. Interestingly, the 12 t-foil rudder can be partially retracted for light air sailing to get rid of the hydrofoil yet leave enough rudder for control. Very innovative! Also, check out the retractable bow foils/flaps on "paradigm"...
http://www.cowes.co.uk/zonexml/story?story_id=5509;cp=0#
National 12, retracting rudder:
http://www.national12.org/adverts/rondar_paradigm2_flyer.pdf
http://www.mcdougalldesigns.com/McDougall_Boats_Foils_Sails.html
PIX: "Tomahawk Foils"(Howes foil) on proto/ Jo Richards National 12 with T-foil rudder and trimtab on daggerboard from cowes.com(above),N12 sailing by Tim Hattersley from sail-world.com and National 12 bow flap/ foils(paradigm),RYD 14.6(Paul Ricelli): (see original post for pictures)
