Pedal Powered Boats
That is still "through the hull". There is an air gap, physical hull material, and water, between the driving and driven magnets.
It is absolutely not through the hull. Most of the pipe is inside the boat in air space. The shaft should be aligned such that the stretch of tube where the magnets are is above the waterline to minimise drag. The magnets could potentially be under a millimetre apart, filed to rounded shapes to get them as close together as possible. I suggested half a millimetre for the tube wall there, but there's no force applying to it anywhere, so it could potentially be a lot thinner still.
Of course, if the leading end of the shaft is in air above the waterline, you can just drive that directly and miss out all the magnets, so maybe the whole idea should be forgotten right enough.
images
The magnetic connection doesn't have to be via drive shaft.
-Will
There are lots of very efficient systems that don't have to penetrate the Stern part of the hull or use magnets, here's perhaps one of the better ones from this list. Using an unsupported long tail flex shaft allows the propeller to always run in a horizontal position without an outboard type right angle conversion, and with a bare minimum of forward appendage water disturbance. Also allows bouncing off of obstacles in shallow water . See post number 53 and 54,
Prop Shaft Systems. https://www.boatdesign.net/threads/prop-shaft-systems.24636/page-4#post-286133
This kind of system was used to set the 24-hour human power boat distance record many years ago.
Maybe simplest way to make efficient waterprop transmission is perpendicular lateral cyclor position .
I'm now thinking the simplest way would be a hole in the stern just above the waterline and with the propeller on a long rod that can be stuck through there when deployed, locking it into a drive shaft which is pedaled directly from the middle of the boat by someone sitting sideways. That would minimise transmission losses, but you don't want to sit leaning slightly aft, so a flexible drive shaft that becomes horizontal at the higher end where the pedals are could be a good solution. However it's done though, it should be designed into the boat from the start rather than trying to fit it as an afterthought.
I thought similarly today but the efficiency of the bevel gear is quite high. The focus should be on the drive screws and gear ratios themselves.
Kind of rare to see a beveled gear at competitive HPB events, probably because of slight weight increase, possible complexity of connecting up, and heavy gear case oils draining efficiency, even when ATF oil is switched out for lubrication. Transverse seating arrangement, or Twisted chain arrangements are far more common, with the focus on having minimum appendage drag, and using large slow turning props for better efficiency. JMHO, others may not see it that way.
What type of transmission did Decavitator use ? High efficiency angular transmission don't need lot of lubrication , just drop of some nano oil. Self lubricating polymers are also available.
I like the idea of a magnetic connection. They have mag drive centrifugal pumps for very acidic/caustic solutions. I bet the mechanism out of a little 1/4 hp pump would be about the right size. Right now I have a 3/8" socket connection in the shaft but since the ball spring is only one side there is a clunk as it rotates. Also requires oring seals on either side which rob power. The magnets might also be strong enough to hold the outdrive to the boat so there is no mechanical connection needed. It would be nice if it slid out when it hits a ufo. I realized that many small boats have scuppers that are in the right location to bring the shaft through the stern.
