PDF to DXF
Discussion in 'Software' started by ThomD, Oct 14, 2010.
  1. ThomD
    Likes: 20, Points: 18, Legacy Rep: 111
    ThomD Senior Member
    Anyone know a reliable, free, way of doing this without malware, etc...
    In my particular case, the drawings I need to convert are relatively simple, if that makes any difference.
    Thanks
  2. Olav
    Likes: 46, Points: 38, Legacy Rep: 460
    Olav naval architect
    I use PDF2DXF. Even the free trial version does the job for me.
    Complex drawings will create relatively large dxf drawings as circles and splines will be converted as polylines only. If your drawings are simple, you'll be better off.
  3. Raggi_Thor
    I use and sell another PDF2DXF program.
    That one, and I guess all others also, can only convert vector based pdfs, not raster. That means you can convert pdfs that origins from a CAD program but not a scanned paper drawing for example.
  4. Olav
    To convert pictures (e.g. scanned drawings) to DXF the guy from my previous post has a solution too: Paper/Picture2DXF
    The resulting DXFs occasionally need a bit of love and care, but nevertheless it's a useful tool.
  5. Raggi_Thor
    Nice, I tried it.
    Here is a tip for new users, after converting or importing, use first Quick Select or similar to select all lines or plines with length below a certain value, for example 30mm in my test drawing, then Polyline Edit or similar (depending on your cad program) and Join with a tolerance.
  6. Joe Petrich
    Likes: 10, Points: 18, Legacy Rep: 141
    Joe Petrich Designer
    If you have Rhino you can import a pdf into Rhino, then export it as .dxf or.dwg etc. It only works with vector based pdfs and all text and dimensions will be broken up into segments.
  7. apex1
    apex1 Guest
    I use "Vector Magic" to vectorize pixel drawings like .jpg .bmp and the like.
    Although not perfect (none of them is), it gives good results.
    Regards
    Richard
