Parallell coupled fish tail boat propulsion
Discussion in 'Hybrid' started by kjellhoegseth, Apr 9, 2007.
  1. kjellhoegseth
    kjellhoegseth Junior Member
    Hi!
    Some years ago I was in a group who went through a week course in the Russian developed innovation technique of TRIZ, and in the "keelwater" after the course, I got the idea ; Why not use the same propulsion principles for boats like the fishes, an waving oscillating tail,or to get more pushing force, set more tails parallell to each other and drive them oscillating mirrorred along a center plane to avoid any swinging tendency of the hull . Should be possible to drive from a common engine shaft like a propeller. The benefit as long as none can prove the opposite, was taken from the idea : The nature (here the fishes)has over millions of years usually found the most energy efficiant way of moving around - and if you look at the acceleration ability of a Barracuda or a Marlin this idea of a swinging tail looks quite impressive. Does anyone have any experiences here ?? Or is this a forgotten good idea.
    kjellhoegseth
  2. Bergalia
    Likes: 40, Points: 0, Legacy Rep: 254
    Bergalia Senior Member
    Parallell coupled fish tail...
    Interesting. But possibly an unwelcome form of propulsion in a tightly packed marina (back-wash). A mechanical form of sculling.... :rolleyes:
  3. kjell
    Likes: 5, Points: 0, Legacy Rep: 31
    kjell Senior Member
    Hi
    Is this something you are looking fore?
    Viste my website for more information.
    http://www.dahlberg-sa.com/kd/Tail.htm
    TREK1
    http://video.google.com/videoplay?do...40064555232864
    TREK2
    http://video.google.es/videoplay?doc...94079313250276
    Cheers
    KJELL
  4. Bergalia
    Interesting idea - sort of mechanical sculling as used in Japan, China etc
  5. jehardiman
    Likes: 974, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Kjellhoegseth;
    While it is fairly easy to mimic the fin sculling motion of slow, but agile, fish; the large powerful fast fish swim with an entirely different mechanisum. Look at the MIT RoboTuna/RoboPike ( web.mit.edu/ahtechet/www/CMI/CMIpt2by2.pdf) or several of the Japanese Fisheries papers on the different swimming mechanics of fishes. Until we mate MPP sensor feedback to an effective mechanical muscle, high efficency propulsion like swimming fish is not really practical.
    Check out this paper: https://ritdml.rit.edu/dspace/bitstream/1850/2630/1/AStreettThesis09-2006.pdf
  6. kjell
    kjell Senior Member
    I have now installed the Wiggle Tail Drive in an R/C model boat. The horizontal mounting works very well. As soon as I have made the navigation tests, I will show you a video with the test results.
    Kjell
  7. Guest625101138
    The best execution of oscillating foils I have seen are the Hobie flappers. Google Hobie Mirage. These get a peak efficiency around 50%
    I played with a large foil. Lots of acceleration because of the swept area and very efficient up to about 9kph. Beyond that the boat starts to bounce and the efficiency drops off. I have attached a video of one of my test boats and photo of the foil used. I later went to a foil that was 1.1m wide and 120mm long. This was the most efficient I tested.
    Things in nature are highly developed but there is no living organism, as far as I know, that has a rotating shaft with unlimited angular range. It is very difficult to make a flapping foil as efficient as a rotating, twisted foil. If flapping foils were really efficient we would see them frequently used on aircraft.
    Rick W.
  8. Guest625101138
    Kjell
    One of things I eventually learnt about foils (wings) is that the efficiency goes up as the aspect ratio goes up. If you look at fast fish like tuna they have a short wide tail. Same thing with dolphins. They have a knuckle at the end of the tail that is controlled by tendons to allow the tail to flex so the angle of attack is not very high. This gets complex to engineer. I did it with a parallelagram linkage and a torsion spring inside the foil. This gives nice smooth angular control of the foil relative to the velocity over it.
    There are some good videas of dolphins and penguins swinmming on the net that shows how their tails operate. There are also mechanically swimmers. Swimming in nature is a a whole body function with the animals having ability to use more than just their tail.
    You would find a short, wide foil at the end of a swing arm would be more efficient. You might find it better to locate the foil under the CoG to reduce pitching if it is an issue. If the boat is pitching then the drive loses efficiency.
    Rick W.
  9. kjell
    kjell Senior Member
    Tail Propulsion.
    When talking about tail propulsion it is important to understand the two different types of movement of the tail.
    1. Slow moving wide foil shape.
    2. Fast fanning flexible fin shape.
    They are producing the thrust in different ways.
    Fast swimming is produced with the number 2 movement.
    Kjell
      File size:
      23.6 KB
  10. kjell
    kjell Senior Member
  11. penguin78
    Likes: 1, Points: 3, Legacy Rep: 22
    penguin78 Junior Member
    The future for propulsion
    Not only is an oscillating tail a neat idea, it is the future of propulsion.
    Your best prop on the best engine is about half as good as a fish tail.
    After seeing the nasa shuttle, and using a computer the sized of a mobile phone, I wouldn't be overwhelmed by the challenge of mimicking a tuna.
    The reason we don't have oscillating tail drives, is laziness, people tend to watch too much television, or spend their money on new handbags.
    Oscillating foils (tuna tail) actually create a jet, by 'shedding vortexes'
    The processing needed to regulate the speed of an oscillating tail is well within the reach of a cheap microprocessor.
    The speed and power obtainable is almost twice that of the best props.
    It will allow electric drives to completely replace combustion engines in a few short years.
  12. kjell
    kjell Senior Member
    In 2007 I made many interesting tests with fishtail propulcion. One of the problems with tail propulsion is that it is not possible to go reverse. This problem is now resolved with my new TAIL POD. The tailpod as you can se on the picture is an electric driven horizontal tail. The TailPod can direct the Jet stream from the tail in any direction, 360ยบ, the same way as modern propeller pods.
    http://www.youtube.com/watch?v=8rxTymeyvf4
    http://www.youtube.com/watch?v=0weQBMVlfGs
  13. hoytedow
    Likes: 399, Points: 93, Legacy Rep: 2489
    Fish back up using their pectorals. Mechanical versions could be mounted forward on the hull, pressed flat out of the way when moving forward.
  14. kerosene
    Likes: 190, Points: 63, Legacy Rep: 358
    kerosene Senior Member
    What a load of unsubstantiated crap. Why don't you start justifying your claims as they are rather huge and definitely need data/info to back them up.
    Lets start going in detail on these:
    and
    Lets focus on these and skip the shedding of the vortexes or the speculation about oscillating/electric taking over for now. I would be happy to make an official bet on the latter though.
  15. penguin78
