Parachute Anchors, Para-Anchor, Sea Anchor
Now that was an interesting article. But I wonder what effect the rudders forced over to one side by the 'reverse' flow is going to have on the moored-from-the-stern' vessel??
Exactly,--and all the other things that beg to be --NOT offered to the seas.
The whole boat is designed to go forward, the bows are made to break the seas and take to force. Hatthes cockpits all made to endure conditions from the front.
Then when it drops to force 7 and you feel like getting on the way how will you reverse into it to slacken the line? ---- transfer to the bow?
The bow is the lightest and will lift over a wave , the stern is not and will be washed.
Different boats different blokes --not for me--
Excellent points. I think I'll turn my prop around and start driving my hull in the other direction!
1) I’m sailing from the Chesapeake Bay down to St.Thomas, USVI on Christmas eve in a heavy full-keel 47 wood cutter staysail ketch. I know there is a storm approaching, but I figure if I can get out past the Gulf stream (avoid the northerly wind against the north flowing current) before it hits, then I will ‘run’ with the wind and waves in the open ocean. It turns out to be a much more intense storm than predicted with a very intense center that moves just north of Bermuda. I experience 60-70 knots of wind for two and a half days. I am surfing BIG but organized seas using a hankerchief-size staysail. It’s reported that two other vessels nearer the center of the low pressure are sunk in the same storm. I have two other inexperienced crew onboard and we are doing 3 hour shifts, as that is as long as you can concentrate on avoiding a broach. I decide the wind is high enough to run under bare poles and save the staysail from gibing itself to death, and maybe keep my bowsprit out of the backface of the wave at the bottom of the trough. We slow down all right, but now the crest of the waves are breaking over my stern and completely filling my cockpit. Tons of water is captured in the cockpit floor space and spills thru the engine hatch seams located there. It’s drowning my brand new diesel engine, and the slower surfing speed has aggravated our broaching tendency. Bilges getting full of water. Back up with the staysail until we are all so tired, I decided to heave to with a rudder forcing her to windward and a backed staysail forcing her off wind. Finally some much needed rest for all of us. I cannot think of a drogue arrangement that I could have left UNATTENDED in this situation, either in reference to broaching tendencies caused by the opposite rotation of the surface waters at the crest of the wave as opposed to that in the trough, nor with reference to the amounts of water I was collecting in the bilges.
This experience of mine was posted in 2006, but it occurred back in late 1980's.
I'm trying to recall the exact year, but my aging brain is not helping me. Does anyone know how to utilize modern computer technology to help with the task?? We left Norfolk on New Years eve, and sailed directly west out into the Atlantic.
I also wanted to see if I could look up Atlantic storms for that time frame. If I recall properly it was a pretty severe storm (originally a severe frontal passage) that we hit between Norfolk and Bermuda,...that sank several vessels, possible even a freighter??
Hi Brian, I can try to help you giving your memories a timeline, maybe Google search results in newspaper articles from that storm if vessels sank..
Was it a really unique or extreme storm? Based on historical weather data we might also figure out the date
I don't understand why they left a floating boat behind. Seem like the problem was discomfort. Also, a strong gale is something any ocean going sailboat should be able to handle.
Those sinking I recall I think were rumors I heard. I was on my way to St Thomas at the time to visit a beach cat rental business I had there in Magens Bay. I got so involved with that business and having fun, that I never noticed how that storm was reported by in the US or on the boating media.
I do remember getting SO TIRED OUT running with storm, the finally figuring out a way to 'hove to' and get some rest.
Do you remember how long it took to reach Bermuda?
"I have been for a long time an advocate for the parachute type sea anchor, deployed from the bow of the vessel, for use as the ultimate survivability tool in really extreme sea conditions"
Yes, If Big If
Yes, provided the rudder blade is lifted out of the water. Otherwise, three things happen: 1) the boat yaws horribly; 2) the anchor line snaps due to friction; and 3) the rudder is damaged or breaks.
[Here a video of a damaged rudder]
[Here a photo of a yacht sinking after its rudder broke while using a sea anchor]
A sea anchor must be used the way our predecessors taught us: by lifting the rudder blade out of the water.
If rational life existed on some distant planet in this galaxy, in that distant planet there would be sailboats capable of:
B) anchoring at sea with the bow facing the waves and the rudder blade out of the water, and
A) surfing large waves in comfort and safety.
175 years to solve two fuxxx problems
I've visualized the available (wind) data from NCEI (National Centers for Environmental Information (NCEI) https://www.ncei.noaa.gov/) from that timeperiod for Bermuda (Not all days have recordings, that's why 1987 starts on january 3rd for example).
I assumed that wind speeds are an indicator for a storm, later I will look into the wind direction as you mentioned it was a frontal passage. Going from England to Bermuda having a frontal storm would likely mean it was a kind of west wind.
Another assumption of mine is that the storm also occured on Bermuda, as I don't know exactly where you've encountered the storm. If you can tell more about the area of interest I might find a better, more suitable weatherstation.
From what the winddata show the most severe storm (or at least, most heavily blowing wind) occured on 4th january 1989, maybe that is the one you are searching @brian eiland
A website which tracks and archives historical 'bomb cyclones' data (from my understanding = storm) January 1989 — Storm Months · bombcyclone.earth https://bombcyclone.earth/storm-tracks/months/1989-01/#NA1989-00014
There is plenty of data on that website I did not take a deep look yet, anyways there are data for the 80s and the North Atlantic, might be worth taking a look!
Attn: mc-rash
I did NOT end up going to Bermuda. I had found a way to 'hove-to' for a day, and then the winds were tolerable enough for my turn to the south-west to continue my trip down south to St Thomas.
Sure does look like that 1989 time frame recorded some of the higher wind velocities.
(but for some strange reason I don't yet believe it was this latter year? I'm wondering if it could have been several years earlier?? )
repeat of my incident,....actually it was new years eve that we left the Chesapeake Bay at Norfork,.....Christmas eve we had been sailing down the Chesapeake in cold weather storm that put a strain on my hydraulic steering system. I had to find and replace seals and fix that hydraulic steering between Christmas and our sea departure on New Years
I see, didn't read well enough and additional to that I thought you meant Norfolk in england.. I'll correct it
There was forecasted a big heavy cold front moving across the USA at time (west to east). I had wanted to leave as soon as possible (that evening) in order to get out pass the Gulf Stream that can get REAL nasty in northerly winds. I guess I didn't expect that heavy of a blow,...I was surfing west towards Bermuda rather than feeling comfortable with a more southerly heading.
If I remember correctly I was surfing something like this sea,...only my vessel was not capable of this cat's speed, so I was going slower and those big seas were catching the stern of my vessel. It was only when I had my small cutter-rig staysail up that I could gain a bit more speed to outrun those breaking crest ...(btw, the seas in my case might have been a bit bigger,..as I distinctly remember more breaking crest)
Then that staysail was flopping back and forth to either side exaggerating our broaching as we surfed down the wave faces. There came a time when I decided I wanted to SAVE that staysail from destruction, ...so I took it down believing I had enough wind to run under bare poles. Turns out I did NOT !!..... and the wave crest were catching me and dumping lots of seawater into my cockpit floor that sat right over my brand new diesel engine. I went back up forward and rehosted that staysail.
