Paper Meche boat
Dave T
Senior Member
Joined
Sep 13, 2011
Messages
250
Reaction score
14
Location
Anamosa Iowa and North Buena Vista on the Mississi
As kids I'm sure we have all probably built something out of paper meche which simply consisted of layers of paper soaked in paste to build up a shape of some kind. What I was thinking was using newspaper and high gloss polyurethane. The way it would be done you would build a simple frame from wood in the general shape of a boat and then use 1/4" mesh hardware cloth stapled to the frame to shape the hull. Then a coat of polyurethane and a layer of paper then a coat of urethane rolled on with with a paint roller to completely soak the paper then another layer of paper and urethane, build up about four layers and then maybe a layer of fiberglass cloth or fiberglass screen then more layers until it was about a quarter of an inch thick. The reason for using polyurethane, it is much cheaper than say epoxy, much thinner to soak into the paper can easily be thinned if needed, is waterproof, is aerobic so any left over can be simply poured back in the can and you don't have to mix it. I'm not sure how this would compare to plywood as far as strength and weight and cost but it would be much easier to form curved surfaces and I think would be worth while experimenting with. As soon as I get time I'll build up a test panel and see how it compares to plywood.
Dave T :?:
I did something similar with correlated cardboard ("fiberboard"). use Tightbond III glue thinned so it can be painted on. I put a thin layer of cotton fabric over the outside with the tightbond III glue, and than put six layers of paint over it. it actually held up well. most important you make it completely water tight, you can not tolerate any moisture soaking into the paper fiber core or it will eventually dissolve it.
this is actually a more labor intensive way to build up a hull as compared to most other methods, so the material cost savings is not enough to off set the other costs and labor effort. Do it as an experiment if you want, but traditional skin on frame, or stitch and glue plywood (even strip built) makes a more durable hull for much less effort.
I've heard of brown paper & varnish being used in the making of model race yachts, not sure about the durability as they probably only spent an hour or so in water once a week.
Jeff.
Thanks jehardiman for the link to the magazine article on paper boats. I thought it was likely someone had used this idea before I'm surprised that somebody on this forum hasn't tried it or maybe they have.
Dave T :)
I see that excerpt for paper canoes was from the 1940's I asked around locally once for the price of a small roll of brown paper it was staggering. to the point I did not pursue the project further.
Quite some years ago, I saw someone was building quite large sailing boat from papier mache.
His article mentioned that he found that cross layered newspaper was a very strong material, and could be made very waterproof.
I wish I had followed the guy up .
For now, this guy has pictures
