Painting order
Discussion in 'Fiberglass and Composite Boat Building' started by fallguy, Oct 15, 2019.
Tags:
  1. fallguy
    So, I am painting my hulls.
    2 coats of interprotect
    2 coats of Petit Vivid
    2 coats of Epifanes primer
    2 coats of Epifanes 2 part polyurethane
    or so I hope
    skip the coatings critique; the boat is all epoxy, so not really needing a ton of interprotect and I like the Epifanes
    the question is all about the order of things
    I had planned the following.
    1. Paint two coats of Interprotect 2000 to 3" above dwl.
    2. Sand the Interprotect with 180 and mask off at waterline.
    2. Paint two coats of Epifanes primer and fair as needed.
    3. Finish the top with 2 part poly to waterline.
    4. Mask off to 3" above waterline and sand topcoat and apply bottom paint.
    The downside to this plan is the entire interprotect will require sanding to prep for the ablative.
    Any advice?
  2. Blueknarr
    Likes: 461, Points: 83
    Blueknarr Senior Member
    Fair before priming. Two coats of primer will only give you a few mils of coating to play with. It would be more "smoothing"than fairing.
  3. fallguy
    sorry, it should say touch ups, but it has nothing to do with the overall question
    our major fairing work is complete on the first hull
  4. Blueknarr
    You planned well.
  5. Blueknarr
    Fallguy,
    A word of caution.
    If you sand thru the primer, re-prime. Do not apply finish paint over un-primed areas.
    One of the purposes of primers is to provide a surface of uniform density and porosity. Substrate density and porosity can affect paint's sheen. Spotty priming often results in splotchy finish appearance.
    Yes. I know this bit. Thanks as well.
  7. E350
    Likes: 2, Points: 8, Legacy Rep: 10
    E350 Junior Member
    fallguy or others: I am here to learn not to critique, so please be patient. I believe that I sourced the Epifanes 2-part polyurethane finish coat you mention:
    https://www.amazon.com/gp/product/B00TUNJRN4/ref=ox_sc_act_title_3?smid=A2ZO16S61GUQY7&psc=1
    Your hull is epoxy, the finish paint is polyurethane. So which Epifanes primer is the best to use: epoxy or polyurethane?
    Epifanes Epoxy Primer:
    https://www.amazon.com/Epifanes-Epo...imer white&qid=1571251583&s=automotive&sr=1-2
    Epifanes Polyurethane:
    https://www.amazon.com/Epifanes-Pol...imer white&qid=1571251872&s=automotive&sr=1-1
  8. fallguy
    epoxy primer---stinky stuff
