painting a catamaran
Discussion in 'Fiberglass and Composite Boat Building' started by rturbett, Feb 20, 2008.
  1. rturbett
    Likes: 2, Points: 28, Legacy Rep: 35
    rturbett Senior Member
    I am going to repaint my boat- a drysailed shark catamaran. I like the gloss look, but I understand that non-gloss has less drag. Can anyone reccommend a paint that puts up with an occaisional wet sanding? The gell coat was in pretty bad shape, which is why I had to paint it in the first place.
    Even though it is dry sailed, I will probably go with two-tone. Gloss above the waterline, and "wet-sandable" below the waterline.
    Thanks
    Rob
  2. the1much
    Likes: 44, Points: 0, Legacy Rep: 696
    the1much hippie dreams
    drag is jus another word for friction right?,,,and doesnt something with a smooth high gloss cause less friction then a rough dull?...even tho i dont think that gloss or dull has anything to do with it,,,its the smoothness and roughness i would think that would cause friction.,,,,some of the fastest paint is bottom paint that "wears" off quickly.,,,but most of them dont stay on the market cause their sold as "bottom" paint,,,which has to do with "gunk" build up on ya hull (which slows you WAY down),,,instead of sold as "speed" paint.
    i'll be glad to see the input on this thread ;)
    are you going to leave this boat in the water or just stick her in fer the occasional sail?,,,,because the extra "speed" you get out of the boat wont last but a few weeks,,,,,then you'll be slower then me in the mornin :D
  3. rturbett
    we just race them sunday afternoons, and a few regattas. They only spend a few hours in the water at a time.
    I'm not sure how valid this test is, but a sailor showed me how water beads up on a glossy surface, but doesn't on a dull surface. That would mean the glossy has a higher coefficient of friction.
  4. the1much
    the water may not bead up on dull,,,,,but did it spread out?,,,,i'd say a better test would be on ya rudder,,keep half glossy,,then dull the otha half,,,,put water on both,,,then tilt the rudder, see which one "hangs" on longest,,,the faster the water or "bead" runs off the faster it should be in the water,,,maybe,,,not sure,,ya confident,,heh ;) .
  5. Kaptin-Jer
    Likes: 18, Points: 0, Legacy Rep: 206
    Kaptin-Jer Semi-Pro
    Over in the material forum there has been an on going discussion on "shark" type finishes which are rough to the touch, but increase speed in the water. I don't believe that these very expensive, very high tech coatings are what you are looking for, but It's possible that this is the type of "rough" bottom coating you were trying to describe. An Awl Grip surface will be very slippery, shinny and you don't need to fine sand. In fact the Mfg. does not recommend sanding. I would stick to what we know works.
  6. rturbett
    Hey Much,
    Using your test, icould just see which way the boat turns- the side that has more drag would make the boat turn toward it!
    I'm not trying to be High tech, but I did ruin the last paint job doing a few too many wet sandings. (granted, it was a poor paint job, so I'm not missing it too much!
    I will probably be giving awlgrip a try
  7. the1much
    no i mean try it while your rudder is off hehehe,,lie it flat,,then put the water on and lift it,,,but since the rudder removal thingy is another thread hahaha it might not work for you,,,the side that the water runs off faster would be the side that you want,,,hahahaa,,,sorry im a little "unclear" most the time heh, but try painting a small piece of glass,,then do sanding (rough) on half,,then keep the gloss on the other half,,then tilt it,,the side that the water reach's the bottom first wins,,,,and sorry for the rudder mix up,,( well not really) ;)
  8. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Go back to bed Jim. The meds are wearing off.
  9. gunny
    gunny Junior Member
    just cause it aint shiny dont mean it aint slick..did that make any since?
  10. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Is a shark's skin smooth and shinny?
  11. the1much
    med time :p
  12. the1much
    i think the slick test should be,,,if you can run ya *** across it and ya hear a "squeak" its slick,,,if all you hear is loud screaming in a voice that sounds like yours,,,its not slick.,,,,now is non-skid shiny or slick?,,,,,im making no cents here
  13. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    I would take any boating advise from a guy living in the desert with a lot of caution
  14. gunny
    gunny Junior Member
    aw well, you know what i mean..
  15. the1much
    desert?,,,,im like in the frakin twilight zone,,,,81 yesterday,,,snowing this morn,,,and back to the 80's
  1. fallguy
  2. SamC
  3. Miscbrah
  4. pescaloco
  5. RochesterSS
  6. n421fn
  7. n421fn
  8. bashley
  9. joebricio
  10. rraney
