Paint problem Aluminium boat
Discussion in 'Metal Boat Building' started by steve123, May 26, 2015.
  1. steve123
    Likes: 2, Points: 0, Legacy Rep: 20
    steve123 Junior Member
    Aluminium boat, the paint has gone milky after 2 years in patches also Orange Peel(Guess thats always been). Any ideas on cause of this problem please ?
  2. PAR
    Without a lot more information, it's difficult to make any recommendations, but the obvious questions are, what type of paint, what conditions has it lived in, etc. It looks to be some chalking, which might just buff out. Have you tried to buff it?
  3. Ike
    Likes: 511, Points: 113, Legacy Rep: 1669
    Ike Senior Member
    Who painted it? The builder or a previous owner?
  4. steve123
    No cant buff out, it was painted by the builder. There are 2 boats but only one gone like this, the other is fine. They were not sprayed at the same time, my impression is this boat was sprayed when humidity was high or someone dropped a can of thinners or something and tried cleaning up.
    Maybe they cleaned up wearing gloves as in one area it look like a glove or material print...contaminated cloth or something.
  5. PAR
    Why can't it be buffed? If it was sprayed, it was with a partly plugged gun or something, as that stipple looks worse than a lousy roll and tip job. If it was mine, I'd just repaint as the finish looks like crap anyway, in spite of the cloudiness.
  6. steve123
    This boat is 2 years old and this is only showing up now, the boat is in Holland so i can only go on what the client is saying that it wont buff out.
  7. steve123
    I have had similar milky patches on interior before that was due to spraying in high humidity.
  8. AndySGray
    Likes: 13, Points: 18, Legacy Rep: 91
    AndySGray Senior Member
    PAR's right, it should improve by compounding
    May be a language barrier,
    Be specific;- ask them to gently hand flat, using some 3M P2000 or P2500 wet and dry with warm water an a little simple green, ideally somewhere inconspicuous.
    If it's modern 2 part paints, those are much harder than the traditional paints and using a basic cutting compound will hardly touch it, especially if done by hand.
  9. AndySGray
    The handrail in the second picture post is not likely a factory issue, not after 2 years
    I've seen something similar before - Are the boats on fresh water....
    with mosquito's....
    The common bug sprays with high levels of DEET will eat into the surface of some paint like paint stripper
  10. Mr Efficiency
    Is it aluminium ? Doesn't look like it. Maybe clear coated ?
  11. steve123
    Yes its Aluminium..more photos
  12. PAR
    Yep, that's my thinking too Andy. I'd start by roughing it in with a 1,500 pad, moving up through 3,000 and seeing how it looks. If you're real anal about it, pull out the 5,000 grit pad and have fun, before the fine polish comes aboard. I know some say you can't buff some of the LPU's but I'll be damn if I've found one yet, that doesn't respond positively to some surface smoothing, so long as it's fully cured and performed correctly (speed, products, etc.).
  13. mastcolin
    Likes: 14, Points: 18, Legacy Rep: 150
    mastcolin Senior Member
    Has the boat been covered with a tarpaulin? This can cause this. You say the boat is in Holland...which implies it has travelled...which does actually imply it may have been covered over in transit
    pps it may not easily buff out. It can be sometimes 'deep' in paint ie too deep to get rid of without sanding with something like p600.
  14. SprayAway
    SprayAway New Member
    Hi steve123, this looks like paint oxidization to me, perhaps the builder used a better priced 2k paint rather than a PolyUrethan paint.
    Ask the gent to spray hairspray on the area then take a picture as he doea it, then after it dries. If the paint goes dark during, it just need topping off with lacquer from a body shop, if it doesnt do anything then youre looking at repainting the sections.
    If the colour stays dark after the hairspray dries, then youre only looking at a cut and polish.
    Hope this helps :)
    Source: i spray paint boats
