paddlewheeler recuction drive
Discussion in 'Propulsion' started by xxdroom, Oct 30, 2014.
  1. SamSam
    SamSam Senior Member
    Here's a smaller version of the bus drive. The fellow told me when he came up to dock it, instead of backing off the throttle, he would just downshift to a lower gear.
  2. parkland
    parkland Senior Member
    Cool idea samsam!
    Only thing I don't like about it, is that it is essentially the same as the bus drive, except replaced the cheap rear axle with a little gearbox it looks like.
    The beauty of the bus drive was that the only special part was the sprocket to the wheel. This design has 2 special parts.
  3. Dave T
    Likes: 14, Points: 18, Legacy Rep: 158
    Location: Anamosa Iowa and North Buena Vista on the Mississi
    Dave T Senior Member
    It would be interesting to know what the final drive ratio is. My guess would be that that gear box has a much lower gear ratio than a bus or truck differential would have and maybe he already had it or bought it real cheap.
  4. parkland
    Looking at the size of it, I don't think it would be rated for much power.
    Big gear reduction boxes capable of 1000 + ft lbs are huge!
    Looks like a pretty lightly built system.
    There could be a huge difference in parts depending on if you want to cruise the odd time, or be able to put major hours on the boat and run it harder.
  5. xxdroom
    xxdroom Junior Member
    31 inches ! not too bad .
    thanks .
  6. xxdroom
    that's a good question......
    make one ?
  7. xxdroom
    the chain thing is second to an actual gear drive with a heavy duty auto rear end .
    of course the rear end would be all lightened up & tricked out .
  8. xxdroom
    hell I`ll take 4-5 of em !
    whew !
  9. xxdroom
    yea........ this is very important.
    must have the correct ratios to operate the paddle wheels.
  10. xxdroom
    CLOSE !
    GETTIN REAL CLOSE !!!! HA .
  11. xxdroom
    IN ALL ACTUALITY........ THE BUS DRIVE "IS" WHAT I`M LOOKING FOR .
    NO SO MUCH THE DIESEL & THE HUGE HEAVY PARTS LIKE THE BUS DRIVE.
    WHAT I WANT IS ALL AUTO MOTIVE .
    I DO WANT TO THANK WHO EVER IT WAS THAT POSTED THE LATEST PICTURE OF THE AUTOMOTIVE ENGINE & TRANSMISSION MOUNTED TO THE DRIVE IN THE BOAT .
    MY IDEA IS TO MOUNT THE PADDLES DIRECTLY TO THE AXELS.....OF SAY A 1 TON 12 BOLT HEAVY DUTY FORD (ETC) REAR END .
    this part is not a problem....... the overall problem is the correct ratios of the paddle wheels .
    I AM BUILDING A SIDE PADDLEWHEELER/S .
    I do have an interest in a stern wheeler but not at this time........ although I am very interested in any paddle wheeler ....... one & all...... keep posting the info & photos !
    it may take awhile ....... buy sooner or later I/we will have it down to a `T .
    just like downtown..........
    like a sunday afternoon.......
    cherry pie in august ......
    peach pie in july......
    A GREAT & SIMPLE COMPLETE RUNDOWN ON THE WHOLE SET-UP !
    A REFINED TO INFINITY COMPLETE PAPER ON THE RATIOS & SET-UP FOR A COMPREHENSIVE PADDLE WHEEL DRIVE UNIT & A TOTAL & COMPLETE LIST OF GEAR RATIOS .
    AND HEY............. HA HA HA HA HA
    WE CAN GIVE OUR END RESULTS & FINDINGS TO THE GENERAL PUBLIC & TO HUMANITY AS OUR LITTLE GIFT TO THE RACE .
    it ain`t all for a few stingy people .........
    its for everyone .
  12. parkland
    It's settled then, just butcher a tractor, leave the engine and transmission together, and install shafts from the rear axles, out of the sides of the boat to the paddles.
    The tractor will have the gear ratio you need without any other drives or chains at all.
    For a boat that big, don't cheap out on a v6 gas engine, use the diesel tractor engine that is made to work lots. You will save a lot of money on fuel, and it will likely be much more reliable.
  13. parkland
  14. myark
    myark Senior Member
    I thought this was a very simple drive system by using the gears of he car for reduction also gives a reverse
  15. parkland
    Really that is identical to the bus drive system, only difference being the powertrain is still in the vehicle, and the paddle is tiny, instead of large.
