sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
https://photos.app.goo.gl/gMPnioASAk6TzoPp6
Right at the water line for about 12 inches, worms destroyed this.
I saved this repair for last, and made good progress last couple days.
I cleaned up what remained of the outer stem using a chisel and grinder.
There a three 1/2" wide long bolts, like from 8 to 10 inches long. The inner stem is very deep and about 4" in width. The outer stem got damaged.
I cut the stem at an angle so the bolts will pull the new wood in tight, and of course it's glued.
I crafted a decent fit white oak piece to fit exactly to the curve shape and then cut the plank end groove when the plank ends land.
I then split that large piece in half for the plank ends to sit at the right position matching it to the existing groove above and below the repair.
The groove I hand ground using 24 grit paper on a rubber grinder wheel and it cut it fast and decently, then used a Dremel with a carbide grinder to clean up.
I will glue in a wedge filler, and then craft a triangular whit oak piece to sit on top.
Oddly the inner stem white oak seems to be wider at the top of the repair, and I also cut the groove deeper than it needed, which is why you see the V between the 2 pieces, it's a tough repair to get it to fit well, and I got it.
Glued in place
Glued in place
