Outboard installation
Discussion in 'Boat Design' started by raymizzi, Jun 11, 2008.
  1. raymizzi
    raymizzi Junior Member
    Need some advise to install a 25hp on a Cyber 370. Are there any hints about the distance between the center of the prop and the bottom of hull?
  2. powerabout
    Likes: 63, Points: 48, Legacy Rep: 719
    powerabout Senior Member
    The simple answer ( I dont know what a cyber 370 is so i'm guessing displacement) is the whole prop needs to get clear water from the hull so the cavitation plate needs to be level with the bottom of the aft part of the hull.
    You may still need to go lower then this to prevent the prop sucking air down from the surface.
  3. raymizzi
    If you visit Youtube 'Cyber 370' the boat No.88 is my son"s boat . Aout the height we have just lifted the engine about 25mm so that the cavitation plate is now the same level with the bottom of the boat. Do you think that how it was the engine gives less revs and now higher revs ? Thanks and regards
  4. tom28571
    tom28571 Senior Member
    Yes, less drag, more speed and more rpm's..
