outboard engine's propeller
Discussion in 'Props' started by kmwoo, Sep 16, 2009.
  1. kmwoo
    kmwoo New Member
    I’m an engineering student and i have a question can anyone help me please....:confused: :confused: :confused:
    i want to know about type of outboard engine's propeller . if i use Wageningen B-series propellers to predict about outboard engine's propeller it right or wrong ??? and could u tell me the series of propeller can use with outboard engine's propeller
  2. baeckmo
    Likes: 617, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    If we are talking "standard" outboards, they are mostly operating in a high-speed, low-load condition and with an imminent risk for cavitation or ventilation.
    For this purpose, the Newton-Rader series would be a better fit; the Gawn-Burrill probably coming next. There is some data on W-B with a cup as well, that may be relevant to you. I'll see if I can produce some references for you later. As you have noted, most propeller matching (not design....) programs have algorithms, based on the W-B series. Due to the cambered blade sections of the N-R, there will be a shift in optimum advance ratio for each pitch ratio when you compare the two.
  3. kmwoo
    kmwoo New Member
    thanks. baeckmo
    could u have Gawn-Burrill curve or Newton-Rader series curve and conference or reference data sheet. i will use it to validate with my thesis.
  4. baeckmo
    Sorry to keep you waiting; got to do some job for those paying my bills now and then...
    Here a few references that may get you on track:
    "Performance Data of Propellers for High Speed Craft" by RN Newton and HP Rader; The Royal Inst of Naval Architects, Quarterly Transactions, April 1961, Vol 103 No 2.
    "A New Usable Propeller Series" by Denny, Puckette, Hubble, Smith and Najarian; Marine Technology Vol 26, No 3, July 1969, pp 173-191.
    "Design Considerations for Propellers in a Cavitating Environment" by DL Blount and DL Fox; Marine Technology Vol 15, No 2, April 1978, pp 144-178.
    "Cupped Propeller Test and Analysis" by Hwang et al; Schiffstechnik Bd 42-1995 / Ship Technology Research Vol 42 -1995.
    Good luck and please keep us posted with your results!
  5. kmwoo
    kmwoo New Member
    thanks. baeckmo for your reference data and your attention in my topic.
