Options for Diesel Engine 1000hp and Up
Discussion in 'Diesel Engines' started by Extra300, Jun 10, 2012.
  1. Extra300
    Extra300 Junior Member
    Looking for some options on a high performance diesel engine.
    Building a Downeast style boat and looking for something in the range of 1000 - 1500 HP.
    Similar to the size of a D13 Volvo
    If anyone has any suggestions that would be great.
    thanks
  2. WestVanHan
    Seeing as a D13 is about 12.5 litres and already at a highly boosted 900 hp......get a bigger engine more suited for your needs or use a turbine.
  3. Extra300
    when i say size of a D13 i mean overall LWH. There are plenty of engines that have more power but get too big.
    Checking into a Cat C18 1150HP and a Man V8-1200
  4. Adler
    Likes: 16, Points: 18, Legacy Rep: 139
    Adler Senior Member
  5. Extra300
  6. powerabout
    powerabout Senior Member
    how much horsepower per litre would you accept?
  7. Extra300
    Probably looking size wise for an 8 or maybe 10 cyl (pref 8)
    need a min of 1100HP but would go up to 1700HP
  8. WestVanHan
    Realize that...but hp also can be rated as in litres of engine physical size. As you discovered,more hp= bigger physically sized engine. The only way around this is with a 2 stroke...which won't work anymore.
    Hoping you don't need the high hp for longer periods of time...
  9. Extra300
    These are 3 engines that state otherwise..
    Cat C18 = 1150 HP
    Man V8 = 1200 HP
    MTU V8 = 1250 HP
  10. WestVanHan
    Well have at it then-try the CAT with it's rated 1150hp and look forward to getting to know your local CAT dealer- MTU and MAN don't have the amount of dealers.
