Sailor Al
Senior Member
- Joined
- Feb 7, 2021
- Messages
- 697
- Reaction score
- 30
- Location
- Sydney
All sail trim books discuss ways to manage the size and position of the draft with the tools at our disposal: luff tension, sheet tension, car positions, rig tension etc,., etc., and then point out how the size and position of the draft is important to handle varying wind speeds, sea states and points of sailing. But none of them explain why.
None of them explain the theory.
Consider this.
All the sailing writers, Jobson, North Sails etc., have learned their theory from the published authors like Marchaj, Gentry, Fossati etc., who themselves have, either consciously or unsconciously, used theories arising from fluid dynamics, like Bernoulli's Theorem, Kelvin's Circulation Theory, Reynolds laminar flow etc., or the classical mechanics of Newton.
None of these writers explain how these theories explain the principles of sail and rig trim.
Why?
Because the theories behind fluid dynamics all use incompressible fluids. Water is an incompressible fluid. Air is a gas. It is compressible. Fluid dynamics doesn't apply to wind over sails.
Newtonian mechanics applies to the motion of objects. Air is not an object - it's a gas!
As you will read in Aerodynamic force on a sail , "the aerodynamic force arises because the sail is compressing the air to windward and decompressing it to leeward."
Maybe some of the mysteries of sail and rig tuning can be explained with Swept Volume Theory, and maybe they may yield an answer to your question.
Certainly, in the past 100+ years, none of the current theories have been of any use.
- Why does a deeper draft produce better performance in light airs?
- Why do we move the draft forward in calm water.
- Why do we ease the sheets and increase the draft when sailing off the wind?
Consider this.
Why?
