opinion of Beta Marine diesels
Fred, what kind of tranny is it?
Its the std Volvo as put together new the Volvo factory
One of the main reasons I chose the engine I did was that it had a steel exhaust manifold. Didn't like the aluminum manifolds commonly employed.
Klassen has been selling engines for boats since the early 70s. In all that time only one manifold needed to be replaced due to rust. Their engines are very popular in BC Canada and Alaska. My base engine is a Mitsubishi and the only aluminum on it is the valve cover, the remote oil filter conversion and the oil filter support bracket. All three are easily replaceable.
I recall my engine cost about $6K in the us through their shop in Ballard (Seattle). I shopped almost everything available except Volvo because of their parts problem. I liked a lot of other engines but the steel manifold and their history of great service up the PNW coast to Alaska settled it for me. Klassen does most of their business with commercial fishermen.
On the original question about Beta-Kubota, I've seen many of these engines perform very well. Never seen Beta-somethingelse
I have marinized a few Kubota myself mainly the Kubota V1505 and they are bulletproof.
I also prefer installing keel cooling and dry stack over wet exhaust but I would never install a tractor manifold in a boat. A tractor or a truck manifold is designed to lose heat via the wind generated by the radiator fan or the speed going forward in an "open box" environment.
I grew up driving open barges powered by old truck engine unconverted, from the orchard to the market loaded with fruit boxes and have seen my fair share of dark red manifold slightly glowing in the dark.
The best of both world is to still use a marine manifold to suppress half of the heat generated by the exhaust, and the dry stack to avoid rusting pipes. All the cooling systems used in marine environment are a compromise but I think the above is way better than a wet exhaust where the manifold and the riser suffer constant corrosion particularly in engines used only occasionally.
If there is no chance to fit a dry stack, the best way is to include the manifold in the coolant circuit (fresh water) and pump raw water through the heat exchange and straight out the riser and the exhaust. This way only the riser will need to be changed every 4-5 years or so and not the manifold.
