One question of outboard engine
Discussion in 'Boat Design' started by Hiro Chen, Jun 17, 2025.
  1. Hiro Chen
    Hiro Chen Junior Member
    Had anybody known there was a ship or boat that applied outboard engine at inboard side, which means it applied outboard engine at front of stern or transom like a POD or inboard engine.
    I'm very sorry for this ridiculous idea, but my boss insisted on this. I have not found any document to let him give it up
  2. fallguy
    Likes: 1,889, Points: 123, Legacy Rep: 10
    bajansailor likes this.
  3. jehardiman
    Likes: 1,373, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
  4. Hiro Chen
  5. Hiro Chen
  6. skaraborgcraft
    Likes: 247, Points: 43
    skaraborgcraft Senior Member
    Yes, there are more than a few trailer-sailer type yachts with CE certification, that have "inboard" outboard-motor wells.
  7. skaraborgcraft
  8. hashtag_laeuft
    Likes: 16, Points: 8
    hashtag_laeuft Junior Member
    Hi ..
    there are also some sailing boats using more or less the same concept. Checkout the following:
    • Seascape 27
    • Saphire 27
    • Reacher 780
    Best regards ...
  9. Hiro Chen
    many thanks, design like this is totally new for me. it is grand help
  10. Hiro Chen
    Hi, thanks for your reply,
    I think it is much easier for monohulls of design category C &D . I got one 40ft sailing catamaran, and primarily used Volvo D1-30 with sail drive as inboard engine. However it could not meet requirements for exhaust emissions standards in my country. If you have any news about type like this, please help me and known. Thank you
  11. hashtag_laeuft
    @Hiro Chen what is the actual purpose of your question? Is it a general conceptual thing or related to a specific design?
    And I don't get the point why the engine or propulsion concept effects the CE Design Category, which covers stability and seaworthiness. Yes, the engine it self must comply to some emission regulatories, etc.
    You wrote that you want to convince your boss not to use such a concept, but it also has some advantages.
    For example it is way lighter than a inboard diesel engine with the same power output.
    The Seascape 27 is constructed in a way that you can take out the engine, with a folding mechanism, during sailing to reduce the drag.
    The engine might be more easy to maintain by a better accessebility.
    Once there was an outboard engine converted to an saildrive on the market, but I guess it is not available anymore, unfortunately. You can Google for "Saildrive 330".
  12. fallguy
    For me, the main reason I don’t like these designs is my uncertainty about what happens to fumes; especially at idle. I’d not want CO emissions inside my boat.
  13. skaraborgcraft
    In most cases the outboards are mounted in open cockpits. In some cases, like the old British Hunter yachts, the engines were in vented cockpit lockers, behind a sealed bulkhead from the accomodation.
  14. fallguy
    Oh, I understand all of that; even tunnels under and the like, but I still don’t like them for that reason.
  15. skaraborgcraft
    I would say the risk is as about as much as sitting inside an idling car, unless you are running an old 30-1 mix 2 stroke Seagull, they can make your eyes smart till under way to clear the smog.
