ONE of Construction? Spray to play?
Discussion in 'Fiberglass and Composite Boat Building' started by FAST FRED, Oct 7, 2005.
  1. Zoro
    Likes: 5, Points: 8, Legacy Rep: 10
    Zoro Size doesn't count!
  2. yokebutt
    yokebutt Boatbuilder
    Hey, if you are going to machine up a large lump of foam anyway, then just make it a female mold.
    Yoke.
  3. Raggi_Thor
    This will be a very expensive method. Making a mold use to cost some hundred thousand dollars. This is justified if you plan to make several boats from that mold.
    I beleive in laser cutting the frames and other internal structure and then make the skin of plywood over stringers or strip planking. Then you save a lot of work, remember the hull is the least expensive part of a boat.
    1. AnthonyExmouth
    2. Chapaef
    3. TJ Cameron
    4. bruceb
    5. member 69256
    6. Bigtalljv
    7. johnnythefish
    8. nickrj
    9. Iridian
    10. Cedric Oberman
