gkentr
Junior Member
- Joined
- Nov 7, 2024
- Posts
- 12
- Reaction score
- 14
- Location
- South Coast Oregon, USA
Hi,
I was sure I was done with boats. Age is catching up, my docking was making my wife cringe,
boat upkeep was being neglected, costs were going up, fun was going down.
So we sold all boats, and sold all the parts gathered over the years, and, after a few months,
began missing having a boat.
That led to fixing a 16' fiber canoe up for a fishing canoe. And that led to taking on one more
abandoned tri-hull to make into a fishing boat. This time light enough for easy handling.
This old boat started out as a 15' Starcraft from around 1973 or so. Open bow, outboard,
with standard equipment for the age. Rotten transom, soft floors, soaking wet "safety" foam,
rock hard rub rails, and something I did not expect to find on a 50 year old boat, evidence
of some of the sloppiest, most slipshod work ever.
No worries, didn't expect much for free. Just wanted a fiber "shell" to build from.
The goal of this new project is a 15' tri-hull, center console, outboard with swim/motor bracket,
around 40 to 50 HP, 4-stroke, 3 to 5 HP troll, three inline seats that fold and convert to
one bunk , and a full width top, about 6' long, for sun shade and some rain protection.
The plan is for the outer shell, and the bottom 10" inside to be fiberglass, no flotation foam
in the bottom, just drainage and air. Everything else to be cedar and some ply for transom
and floors. I'm leaning towards using fence boards for cost savings. Safety foam in the sides
and under the narrow decks.
The only place we plan to use this boat will be on the local lakes and flat rivers around south
Oregon coast, of which there are plenty. I expect at least 1 or 2 years of work. Budget project.
So far I have stripped out most of the old rotten floor, stringers, transom, soggy foam,
dirt and bugs. Still a lot of leftover glass bracing and sloppy folded over roving and such
to clean out. Into the trash can a few parts at a time.
Unanswered questions include :
Why would an old guy, 75, who should know better, start another project like this.
How best to glue new transom ply to the old cleaned off glass.
What material to use for new stringers. Leaning toward glass covered closed cell foam.
How best to attatch cedar topsides at gunnels to glass sides. Center console to rest on stringers.
What material to make the swim/motor bracket out of. i have used steel , wood,
and aluminum in the past to make brackets.
Any thoughts, sugestions, replies, or criticisms welcomed.
kentr
kentr
