On center or Off center mount
Discussion in 'Outboards' started by rasorinc, Dec 20, 2014.
  1. rasorinc
    rasorinc Senior Member
    Ready to cut out and glue up transom for 2 outboards. Main engine is 60hp
    and kicker is 9.8 hp both 4 stroke 20" legs. The hull is 8'wide x 28' and the aft 10.5' is a flat dory hull V ing as you go forward to 3/12 then to 6/12 then to 9/12 pitch 3' aft of the bow.
    The 60 is 16.4" wide with a 16.1" swing each way. The 9.8 is 14.4" wide with a swing of 13" each way. Boat will be used for long river cruises on US rivers and lakes and is a live aboard for several weeks at a time.
    Should I center the 60 hp and mount the kicker off to one side or center both based on 1/2 of the combined weight or some other formula?
    Both engines will have equal use as I am in no hurry and have to watch my fuel use. Want best fuel usage and and power usage (performance ) and controls are mounted inside the cabin. Never have owned outboards before only inboards. Thanks much for any assistance. Forgot to mention the transom tilts 14* a 3/12 pitch.
    Likes: 1,428, Points: 123, Legacy Rep: 2031
    I would install the main motor in the center and put batteries on the opposite side of the kicker for balance.
  3. kapnD
    Likes: 279, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    How about mounting the kicker on a raise/lower bracket on the back of the main OB so they are both on the centerline and steer by the same mechanism?
  4. Mr Efficiency
    Likes: 1,036, Points: 113, Legacy Rep: 702
    You don't want an outboard running behind any kind of obstruction, I'd be thinking of using your dead main engine to steer when the "kicker" is supplying the go-forward, and have it locked into the dead-ahead position. Obviously it won't work for tight manoeuvres, but for general travel it will.
