SoccerGuy3
New Member
- Joined
- Jun 17, 2024
- Messages
- Reaction score
- Location
- Northern California
I recently replaced the floor in my 1976 Merlin with a OMC Stringer outdrive. I am now reassembling and ran into a problem putting in the new transom seal.
No issues getting the seal itself positioned into the groove (channel), but when I try to tighten down the band clamp it hangs up on the edge of the groove. The rubber is fully seated into the groove, but the clamp just won’t sit fully in. I can get it in properly at the top, but the rest of the way around it seems to just catch the lip of the channel. If I loosen the clamp, I can pull it back into position in the groove, but as soon as I start to tight the clamp, it walks its way toward the motor and onto the lip of the groove.
Is this normal? Seems like the clamp should sit down into that groove for proper seal. Any tricks to getting this to stay where it belongs? Do I need a new clamp?
