Ok I don't own it
Discussion in 'Powerboats' started by Boston, Sep 15, 2010.
Thread Status:
Not open for further replies.
  1. peter radclyffe
    Likes: 111, Points: 73, Legacy Rep: 680
    peter radclyffe Senior Member
    now you can get started
  2. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    first thing you want to do is soak it in Daniels kerosene tank
  3. rasorinc
    rasorinc Senior Member
    Yes Bos, use the square drive heads in bronze screws. Much easier to drive and remove and do not strip out like phillips or regular heads--happens a lot with bronze as they are not as strong as steel. can you handle left hand drive? English are you????
  4. PAR
    Square drive are also easy to drill out if you strip one. Now you've done it, welcome to the world of pain and frustration, known as old wooden boat ownership.
  5. WestVanHan
    Well it's about $%^&in' time ;)....congratulations.
    Maybe check Craigslist for storage?
    And even take out an ad on Craigs..make it stand out,like this: ******************Boat Storage Wanted******************
    BTW there are special easy outs for Robertsons,not that you'd need them.
  6. M&M Ovenden
    Likes: 80, Points: 38, Legacy Rep: 527
    M&M Ovenden Senior Member
    robertson drives
    One of the best Canadian products*. My home town is where it all started.
    http://www.robertsonscrew.com/
    * Let's not forget maple syrup & smoked salmon (best when combined to make "candy salmon" )
    I know, way off topic.....
    Cheers,
    Mark
  7. Brian@BNE
    Likes: 13, Points: 18, Legacy Rep: 151
    Brian@BNE Senior Member
    Ok, you'll soon be having fun by the sounds of it. Will make quite a change.
    I'd suggest you do all the repairs first, then test the market on resale just in case you can be tempted. Be careful with your planned improvements, they might just make it less attractive for potential buyers despite being perfect for you. That's been known to happen:p
  8. hoytedow
    That is a beautiful hole into which you can throw money. Congratulations!
    A-li-he-li-tsi-da-s-di!
  9. Landlubber
    Landlubber Senior Member
    ...OK Boston, nice little boat, let the games begin.......all the best mate.
  10. troy2000
    troy2000 Senior Member
    Well, I've learned a few acronyms over the years. One is 'BOAT': Break Out Another Thousand.
    But I shouldn't talk, because I have a bad case of 'JEEP': Just Empty Every Pocket....:p:p:p
  11. Boston
    Boston Previous Member
    thanks guys
    I've waited a long time and tried my best to learn what I can
    now to make it my own
    I'll be sure to not screw it up as I have a lot of great folks behind me who I'm sure wont let me down
    that and I intend to keep on my NA if he is willing
    I was thinking of having him draw up a set of prints for the boat so that any alterations might be more easily checked for stability and performance issues
    the changes I want to make do add a bit of weight aloft and I'm not interested in creating any problems
    so maybe the proposed changes are not entirely feasible
    who knows
    thanks again folks
    its been a long road and although one journey has ended
    another has just begun
    you folks have been invaluable
    I cant thank you all enough
    my most heartfelt thanks to you all
    its nice to know I have such a great group of folks behind the adventure and although I cant say its not kinda nerve wracking to make such a huge commitment
    at the same time
    I know I have some great resources behind me
    thanks again
    B
    ps
    I prefer square drive any day
  12. dskira
    dskira Previous Member
    Look at the wheel detail. To die for.
    She is beautiful, you will have the time of your life on board.
    I like the aft cabin, simple and seams very cozy.
    I have her in the book Wooden Yacht of the Northwest.
    The interior with the stove is beautiful. The overhead lamp is quite ship style in the galley.
    They fortunatly changed the wheel binnacle from the picture, it was white.
    At 9'6" you just need a over size banner to transport her, no escort. Must not be very expensive.
    A beautiful yacht. I am happy it's yours.
    Daniel
  13. Boston
    ok so lets talk turkey
    I want to add some raised panel to the wheel house and glass in the area under the canopy
    I'll add more posts in and keep the spacing the same from whats already there
    carry them down the inside of the bulwark just like the one you can see by the pilot station and tie them into the framing
    the raised panel will top off at the line of the raised deck and go aft to where the canopy ends
    I'll build little doors either side of the seat for access to the aft deck area which I will want to cover with a cloth canopy that follows the same line as the hard one does
    eventually I want to extend the trunk cabin all the way aft to the transom and build a nice seat on the roof of it
    all in keeping with the style of course and made to look like it had always been there
    blending in the design to match the original "feel" of the boat
    cheers
    B
  14. wardd
    wardd Senior Member
    yea, inside steering would be more comfy
  15. Boston
    Rumor has it that there is often a cold breeze running down the passage, I'd kinda like to stay nice and warm in a heated pilot house, The boat has a Dickenson diesel stove/heater so why not put it to good use
    a few specs
    Additional Specs, Equipment and Information:
    Boat Name
    Haidda Princess
    Specs
    Builder: R.D. Helmer
    Dimensions
    LOA: 36 ft 0 in
    Beam: 9 ft 6 in
    Maximum Draft: 3 ft 6 in
    Engines
    Engine Brand: Volvo
    Engine Model: TMD 40A-1986
    Engine Hours: 1700
    Engines
    Total Power: 91
    Cruising Speed: 8.5 K
    Max Speed: 12 K
    Tanks
    Fuel: 150
    Fresh Water: 35
    Holding: N/A
    Accommodations
    * Classic bridgedeck cruiser with an aft cabin twin berth arrangement, center wheelhouse, and galley/head/berths forward.
    Galley
    * Dickenson Diesel stove / oven
    * Micro wave
    * Sink-pressure water
    * Marble countertops
    Electronics
    * Depth finder
    * VHF
    Electrical
    * Inverter-1500 watt
    * RM-20 Newmar charger
    * Link 2000 monitoring system
    * 2 new 8D batteries-2005
    * Original knife switch sub panel
    Deck
    * 12 volt Bronze McMurry windlass
    * 150' 3/8" chain
    * 1912 Navy 30# anchor
    * 1920 "Two Mile" brass spotlight
    * Original copper and brass running / anchor lights
    * Original solid bronze 1920's Wilcox Crittenden head-fully restored.
    * Leaded glass "Orca" window panes
    Additional
    * Complete "out of water" survey 6/06
    * 2009 "in water" survey also available.
    * Also surveyed 1990 / 1995 / 2000
    * New bottom paint 6/06
    * Boathouse and Yacht Club space available.
    * Aft cabin-raised panel ribbon grained mahogany
    * Hull-Alaskan red cedar
    * Deck-Teak / cedar
    * Cabin trim-Burmese teak
    * Framing-Oak
    one reason I would extend the aft cabin would be to put an up to date head and shower in there, nothing that looked out of keeping withe the style but just a working head with a holding tank, that and a mini washer dryer. I'm not sure what is in the area forward of the transom but aft of the trunk cabin but if its hollow its about to become used for something
    cheers
    B
    oh
    who has a handle on ribbon grained mahogany and Burmese teak
    I'm going to need some in order to match the existing
    I'm also going to add a heater to the aft cabin
    that and make the two singles into one large accommodation
    Thread Status:
