Offshore bracket pod rounded edges??
Discussion in 'Hydrodynamics and Aerodynamics' started by Let_Freedom_Ring, Apr 11, 2020.
Tags:
  1. Let_Freedom_Ring
    Let_Freedom_Ring Junior Member
    Gonna build one soon, was wondering which edges should be rounded and which might benefit from a larger radius or close to none at all.
    which areas might create the least splashing on my motor? Also how will square vs radius have on performance? the bottom corners (sides, back)?
  2. kapnD
    Likes: 540, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    All the bottom corners should be squared off, or water will climb up the sides at speed.
    Let_Freedom_Ring likes this.
  3. Let_Freedom_Ring
    Thank you so much!!!
