SpongeDave
- Aug 4, 2021
- Messages
- 96816
Will peel-ply (or taffeta, or ripstop nylon) readily 'vent out' trapped air? If yes, what's the heaviest (easiest to keep flat) format of the stuff I might scrounge up somewhere?
If it's ALL too floppy, would it make sense to stretch it around a flat form like plywood, hoping for it to allow bubbles to vent out somehow?
Gory details:
I'm grappling with a filled-epoxy application that's got nothing to do with boats, but I'm guessing there's some good advice available here. My guesstimate at adequate slope for drainage on a new balcony wasn't great, so I've been adding some slope to it using heavily filled epoxy. I've done a number of batches using a large (55" square, 1" thick) HDPE "flattening form" lowered over the wet, troweled mass of filler. I first trowel the filler out with a heavily-vee-notched trowel, knowing I'm going to end up with defects/furrows between the perfectly-planar peaks (where the HDPE flattens them). The idea was they'd be perfect guides to let me make the whole thing planar with my new added slope once all is done.
But from there, it doesn't go as I'd like, mainly because there's nowhere for air to escape in subsequent applications. So the best I can do is eyeball-trowel back over the surface. Then inevitably it's going to take another application...then that turns into two more...etc. ENDLESS. And not-so-perfect results, especially when micrometer-thin bubbles of epoxy form in places, trying their best to evade my detection until I think I'm done - at which point they'll break through after I put the UV-resistant coating over the top...
So as I asked at the top: does peel-ply have a place in this process that would release me from some of the endless batching, troweling, sanding events?
Gory details:
