Ike
Senior Member
- Joined
- Apr 7, 2006
- Messages
- 2,751
- Reaction score
- 528
- Location
- Washington State
No drains? One of the first things I learned about boats way back in the 60's was, all boats collect water in one way or another (leaks, rain, dew, moisture in the air that condenses on cold surfaces, etc). They also taught me all boats leak! This is why boats have bilges, and really small boats like dinghies are stored upside down. You don't want that water collecting where it's going to soak into wood. This is as true for fiberglass boats as it is for wood boats. You need a way for the water to drain to a place where it can be removed either by a bilge pump (when the boat is in the water) or a drain (when the boat is on a trailer) That's done by what are called limber holes. They aren't really holes. They are just a notch on the bottom of stringers and transverse floors, that allows water to drain aft to a small sump where the bilge pump is. That's why it's important to coat the stringers and transverse pieces with resin or whatever to keep the water from soaking into the wood while it's draining away. If you don't have a way for it to drain then you've trapped it. If you trap water it causes rot. Water can migrate through almost anything, including fiberglass and resin, given enough time.
PS: Where in Hawaii? I have relatives on Kaua'i. I've been thinking about visiting them.
