Newly Invented Jet
Discussion in 'Jet Drives' started by Ximing Huang, Jun 7, 2012.
  1. Ximing Huang
    Ximing Huang New Member
    In this invention, the fluid runs inside a loop of two kinds of materials. At the two joints, heat may be produced to have a refrigeration or flow.
    If the loop is open, a generator is there with no propeller at all.
    The water or any other fluid may flow from the hot end absorbing heat to the cold end emmiting heat.
  2. Mr Efficiency
    Anyone who can understand this is ahead of me.
  3. J Feenstra
    Likes: 6, Points: 0, Legacy Rep: 100
    J Feenstra Junior Member
    umz... nice art?
  4. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    me too
  5. Ximing Huang
    simple principle
    Well, the invention herein means that if there is two different densities of the same kind of fluid, then the fluid flow may generate heat at the two joints. Also, the heat absorption at one joint and the heat emission at the other joint may generate a flow.
    It is quite like the principle of the thermoelectricity effect.
  6. J Feenstra
    and this has been tested?
  7. Mr Efficiency
    I always was slow on the uptake.
  8. Ximing Huang
    Well this is only an idea.
    I hope you understand the thermoelectricity effect to compare with the invention. That shall be rather easy.
  9. mydauphin
    mydauphin Senior Member
  10. Ximing Huang
    It has nothing to do with the magnet at all
    This invention does not use any kind of magnet or electrics.
    It simply uses two kinds of porosity materials.
  11. rubenova
    Likes: 4, Points: 8, Legacy Rep: 49
    rubenova Junior Member
    It's like I tell my wife..."pretend I don't know what your talking about." Tell your readers what your on about. Are you looking for financial backing, are you asking a question... throw us a bone man :)
  12. mydauphin
    Porosity. Material ... what an osmotic drive? It could take decades to travel a mile. Please get real.
  13. jim lee
    Likes: 20, Points: 18, Legacy Rep: 247
    jim lee Senior Member
    Ford Model T cooling system? Even Ford gave up on it and added a pump.
    -jim lee
  14. Frosty
    Frosty Previous Member
    Thermo syphon cooling --not even close to what this guy is on about.
    Oh and it worked fine if you have a high radiator.
  15. jim lee
    I had a model T. It worked marginal at best.
    -jim lee
