You guys really seem to have your "stuff" together and I cant get the right answer from my local shop. I have tons of hours into this project with disastrous results both times. I will try to be brief.....
Jet ski that I am restoring. Repaired a couple spots in the hull without incident using polyster and glass, and used Everlast filler for some of the minor stuff and touch up before primer.
I am trying to gelcoat the hull. I have reasonable talent, but no gelcoat experience. Determined to the point of stupidity to learn and do this myself. Here's what I did the second time....First time I think I forgot to add catalyst in one of the gelcoat layers(panicked when I didnt mix up enough and thought it would go off in the gun) and had to wire wheel off the gooey mess, so 8 or so hours minimum wasted. I have a nice shop with a paint booth, keep a fire going at about 65 degrees clean environment.
Started with repairs and got it relatively smooth. Cleaned it with Acetone and then hit it with epoxy primer. MP 170 and 175. Wait 12 hours, Light sand and repeated primer coat again . Primer looked perfect, sprayed with 1.4 tip
Wait 48 hours, Scuff sand with 220, wipe down with dry rag and vac.
First Gelcoat spray with 2.2 tip consisted of:
Fiberlay Gel coat white
Fiberlay styrene polymer 10% to thin
Fiberlay catalyst at 3%. (washington state, high humidity, but fire in shop at 65 degrees)
Looked perfect, waited 5 hours.
Same Fiberlay mixture as above but added 1/2 oz per pint of mixture(per instruction) of Fiberlay surface seal.
It layed down nicely and then......EXPLODED into the ugliest wrinkly old lady skin you ever saw! Not the alligator look of under application but a wrinkle that looks like a reaction or gases trying to get through and wrinkling the sh*& out of the final coat.
I really haven't the slightest about what to do now. My initial thought is to sand it smooth in a day or so after it hardens up, if possible without removing everything. Use the epoxy primer again and paint the damn thing. Hoping to run this by some wiser minds than mine and the guys that have been taking my money for gelcoat and sandpaper.
I understand that they are not responsible for making me a master painter-not putting the blame on them, just frustrated.
Any recommendations are welcome. I am quite inclined to scrap the gelcoat and looking now for a fix so I can just move on because I really want to paint the body!
I will try to attach an image and will try to pay it back as I learn more.
