newbie question, what encounter frequency means?
Discussion in 'Hydrodynamics and Aerodynamics' started by cristianon, Apr 9, 2017.
  1. cristianon
    cristianon Junior Member
    hello sir,
    image hosting gif
    is there anyone who can explain what's the meaning of encounter frequency and it's formula on RAO graphic?
    thank you
  2. jehardiman
    Likes: 504, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Encounter frequency is the derived apparent seaway frequency corrected for vessel speed and direction. So a vessel heading into the seaway has an encounter frequency greater than the seaway. Likewise, when running with a seaway, the encounter frequency is lowered. Beam to seas gets kind on tricky as the encounter frequency could be zero, but not really due to the difference between a nominal single frequency calculated RAO response and an irregular seaway response.
  3. Ad Hoc
    Likes: 855, Points: 113, Legacy Rep: 2488
    In addition to JEH's post
    Looking at the graph, the peaks are around 1.5 rad/s...so this means a period of roughly 4.2 seconds. So if the vessel encounters a wave every 4.2 seconds, from whatever speed direction (as noted by JEH), the response is increased. So for a unit wave of say 1.0m the response is almost 4 in heave. In other words, when encountering a wave every 4.2 s with a wave height of 1.0m the vessel shall heave 1 x 4 = 4.0m.
    Similarly if the encounter is say 6 rad/s or every 1.0 s the response is almost negligible; since 1.0m x 0 = 0 !!
    Conclusion, avoid the peaks, or resonance.
  4. cristianon
    thank you for explanation sir,
    Sorry but i wanna know, how do you get the period 4.2 seconds sir?
    thank you
  5. Ad Hoc
    Hmmm...sorry, if you are unable to work this simple one out...then the rest is way way beyond you.
  6. hoytedow
    Isn't the period the amount of seconds it takes 2 consecutive wave crests to cross the same geographical coordinate? If the coordinate is constantly changing as in the bow of a ship the period between crests would be lengthened or shortened by the rate of travel of the vessel.
    I think I just wrote the same thing jehardiman wrote but in different words.
    http://serc.carleton.edu/introgeo/interactive/qotd/waves2.html
  1. six four
  2. alesserfate
  3. nzl51
  4. Brian Needham
  5. massandspace
  6. Southern Cross
  7. laukejas
  8. mydauphin
  9. mcarling
  10. Anatol
