Newbie builder question, help is appreciated
My son now has my 12 ft plywood boat i built in 89 or 90. Still in good shape for its age. But we avoid standing fresh water ,never leave life jackets in boat to hold moisture and always let it dry out.
No. If you think about. Back in the older days salt was used to preserve meat.no fear unless you got a steel boat
I think i may go with marine grade as i cant find any good exterior wood, just pressure treated cdx on homedepot, and the same for lowes
Im new to this site, but i grew up building boats and commercial fishing. It is said that lifes most valueable lessons learned are learned from failure,not success. I have made many mistakes and i still learn every day. Ask some of the old timers. Thats where i learned a lot
If you want to last a lifetime and want to get by cheaper.i have fiberglass sheets 30foot long and six foot wide x 5/16" thick.....you can build entire boat from one sheet. Cheaper than you can buy plywood.$300.00 a sheet. Thats less than $2 sq ft. And it has one slick finished side.no more rot. Never gets heavier
Check out the boat i just built from these same panels.just look at my pics in profile.its featured in national fisherman magazine march 2013. Artical called lafitte for a king
Well the problem is you're 500 miles away, Can I build a lumber yard skiff with the same principles as a stich and glue boat with it?
Yes , basically the same, a little bit different. But about 1/3 the time and a whole lot less money. Plywood soaks up a lot of resin. Fiberglass sheets does not. Seams have to be gouged out and laminated from within the core outward i gouge my seams 4 inches back on each sideb. That way you get a good bond. That way you dont remove all your glass when sanding back flush
I can email you the artical.if you want to check it out
OK im going to get 7 sheets of 1/2inch 4x8 meranti plywood, then the rest will be regular lumber.
16ft 4x4
20ft 2x8
40ft 2x4
16ft 1x8
3 1/2" 4x8 cdx grade (siderails, compartments, etc)
1 3/4" 4x8 cdx grade (inside of transom)
looking at 800 for all the wood... Dont know weather to epoxy the whole outside or not
Ill take the console and 25hp off my 14.5 foot boat
