New trimaran concept?
Discussion in 'Multihulls' started by stove, May 5, 2015.
  1. stove
    stove Junior Member
    Hi all.
    Has anyone built or designed a trimaran 20ft-40ft where the amas can slide FORE and AFT? Think of the possibilities:
    Slide the amas aft in the harbour or when stationary or while just cruising slowly, this will create lots of extra buoyancy for a much bigger cockpit than usual.
    Slide the amas forward for extra buoyancy in the bows for sailing downwind fast, this should help with the problem of burrowing (pitch-poling)
    Or keep amas in normal position for normal sailing
    A fast trimaran with a BIG cockpit extended towards the amas sounds like a great idea to me (party platform that can sail fast)
    This could be low-tech where adjustments are made while boat is stationary or hi-tech where adjustments are possible while sailing fast. Whether this will be allowed while racing is another question.
    What's your thoughts on this concept?
  2. pogo
    Likes: 10, Points: 18, Legacy Rep: 73
    pogo ingenious dilletante
    Who needs such a ...... ?
    pogo
  3. Mr Efficiency
    Sliding one forward and the other back is another option !
  4. stove
    stove Junior Member
    another option indeed, I can picture it already
  5. mundt
    mundt Junior Member
    dragonfly
  6. waynemarlow
    Likes: 50, Points: 28, Legacy Rep: 134
    waynemarlow Senior Member
    Scissors
  7. pogo
    A trimaran using CCC (Claude-Chappe-Concept) should be named
    "Semaphore"
    https://www.fh-kiel.de/fileadmin/da...d_Wissen/Computer_oeffnen_Welten/semaphor.jpg
    both amas forward means " too much wind"
    port ama forward , mainhull and STB ama side by side means " today little STB wind only"
    all three side by side means " no wind"
    both amas back means " party"
    one ama fwd, other back means " hangover"
    pogo
  8. redreuben
    Likes: 285, Points: 83, Legacy Rep: 349
    redreuben redreuben
    Broken
