New small Multi from Icarus
Discussion in 'Multihulls' started by Manfred.pech, May 31, 2016.
  1. oldsailor7
    oldsailor7 Senior Member
    Boggles the mind, :) Where does the mast go ?
    And why the inefficient sail rig. ?
  2. Manfred.pech
    Likes: 123, Points: 43, Legacy Rep: 319
    Manfred.pech Senior Member
  3. Manfred.pech
    New pics
    Mast and daggerboard hull [​IMG]
    Cabin entrance [​IMG]
  4. patzefran
    Likes: 69, Points: 28, Legacy Rep: 10
    patzefran patzefran
    It seems the beams no more corresponds to the original drawing. what is the rationale now ? I don't see any attachment with the outrigger.
  5. Manfred.pech
    Yes, problem not yet solved.
  6. upchurchmr
    upchurchmr Senior Member
    This is not a little problem.
    It might work as a flower planter.
  7. patzefran
    patzefran patzefran
    Strange, why he doesn't followw the plans of the designer ?
  8. ElGringo
    Likes: 4, Points: 18, Legacy Rep: 48
    ElGringo Senior Member
    I think that boat is being built by the designer
  9. Munter
    Likes: 12, Points: 18, Legacy Rep: 125
    Munter Amateur
    My guess is that the float will have some kind of receiving structure for the stub of the beam which allows the float to slide in and out to adjust beam for transport. That guess is based on less than 2 minutes familiarity with the project though so is a pretty wild guess.
  10. upchurchmr
    Take a look in the 3rd picture in post #9.
    There appears to be the end to an aka, similar to the pictures.
    It may just be positioned, not fastened.
    Interesting thing is that the last picture with the port and hulls in position (post 20) does not have a mast position in the non-cabin hull, although one is clearly shown earlier in post 18. Apparently in the place the "picture" shows the mast.
    I suppose we should just wait for Brian Peterson to post again and fill in the blanks.
  11. Manfred.pech
    The beams
    The problem has been solved.
  12. hoytedow
    That looks like a good solution.
  13. brian eiland
    brian eiland Senior Member
    Why is it that just because it is NOT a 'normal sloop rig' does it have to be labeled 'inefficient'??
  14. ElGringo
    It looks plenty efficient to me. I like the way it looks, I might not like it after I had to fold up my ancient legs to get in but, I would still give it a try.
  15. Manfred.pech
