New Launch - Longitudinal Strength Limit Calculator (under 90 m) - TheNavaArch
Discussion in 'Software' started by thenavalarch, Oct 24, 2019.
  1. thenavalarch
    Likes: 16, Points: 8, Legacy Rep: 43
    thenavalarch Junior Member
    Hello and greetings from www.thenavalarch.com!
    We are pleased to launch a new product - the Longitudinal Strength Limit Calculator for vessels under 90 m in Length
    This Excel sheet helps you evaluate the key parameters for Longitudinal Strength Computation for ships under 90 m at a specific section along the length of a Ship
    • Maximum Wave Bending Moment
    • Maximum Wave Shear Force
    • Minimum Required Section Modulus
    • Minimum Required Moment of Inertia
    The required values can then be compared against the actual calculated ones to assess the suitability of the vessel
    It is based on ABS Steel Vessel Rules for vessels under 90 m in length
    To learn more, please click on the image above or the link below.
    https://thenavalarch.com/software/ship-design/longitudinal-strength/longitudinal-strength-limit-calculator-under-90-m/
    Best wishes,
    Team TheNavalArch
  1. thenavalarch
  2. thenavalarch
  3. thenavalarch
  4. thenavalarch
  5. thenavalarch
  6. thenavalarch
  7. thenavalarch
  8. thenavalarch
  9. thenavalarch
  10. thenavalarch
