New Launch - Keyless Propeller Fitting Calculation App
Discussion in 'Software' started by thenavalarch, Jun 18, 2019.
  1. thenavalarch
    Likes: 16, Points: 8, Legacy Rep: 43
    thenavalarch Junior Member
    Keyless Propeller Fitting Calculations - TheNavalArch https://thenavalarch.com/software/ship-design/keyless-propeller-fitting-calculations/
    Based on American Bureau of Shipping (ABS) Rules, Part 4 , Chapter 3 , this application provides a comprehensive set of calculations for fitting of a keyless propeller. It takes in the geometrical inputs of the propeller together with material inputs and vessel’s parameters to give as output the critical parameters like
    • Minimum pull-up length
    • Pull-up load
    • Minimum required mating surface pressure
    • Hoop and equivalent stress
    The app is easy to use, and has in-built table to pick inputs like material type for hub and shaft.
    Available only in SI Units
  1. thenavalarch
  2. thenavalarch
  3. thenavalarch
  4. thenavalarch
  5. thenavalarch
  6. thenavalarch
  7. thenavalarch
  8. thenavalarch
  9. thenavalarch
  10. thenavalarch
