New installation
Discussion in 'Electrical Systems' started by GWB, Mar 17, 2008.
  1. GWB
    GWB Junior Member
    I have what is probably a dumb question about a new electrical installation in a sailboat.
    There will be 2 batteries (house and starting) an alternator, a 1 or 2 or both battery selector switch and a battery charger.
    What would be used for wire size and do I need to put diodes in the wiring?
    Thanks for any help
  2. KnottyBuoyz
    Likes: 55, Points: 0, Legacy Rep: 685
    KnottyBuoyz Provocateur & Raconteur
    Wire size will be dependant upon the load carried by the conductor and the length of the circuit. You will not need diodes in the wiring. If you want to charge both batteries from a single source (alternator) I'd suggest the Blue Sea "Add a Battery" set which consists of a switch and battery combiner.
    http://bluesea.com/products/7650
    This makes it simple and goof proof.
    To determine the size of the wire you'll need you can use either a "wire sizing" chart (published on the Internet in multiple places) or this "Wire Sizer" program from Aldun Trull
    Just remember the length of the run includes both sides of the circuit from battery to load and ground back to battery. There's also the BoatDesigns Wiki with loads of info.
    http://www.boatdesign.net/wiki/Electrical_systems
    Good luck.
  3. GWB
    GWB Junior Member
    Thanks for that KB.
    Do you perhaps have a wiring diagram that I could reference?
  4. KnottyBuoyz
    If you look on the "product documents" tab on the Blue Sea site you should find everything you need.
