I made a new helm for my 1979 glasply to try and give it a updated look. I also want to update my wiring to something more current. The original setup has a AC/DC panel near the cabin door which houses 4 AC breakers and 6 DC fuses. for now the AC will remain the same but the DC fuses are being replaced with 2 bluesea 4306 switch panels that have the fuses built in. Each panel is rated for 6 15amp fuse or 90amp. The original has 6 wires I believe 12awg that run about 18' to the helm switches. Since the new switch panels have fuses built in I need some clarification on how to get adequate power to the panels. I wont be using all 90amps of each panel but I will need power for other items up there such as nav equipment and other small items. From what I read for my amps and footage I need to run a 1awg wire to supply 80amps. My thought was to use 2 bus bars to run 4awg wire to each one giving me approx 40amps each bus. From the bus I can run short distances to the switch panel with 10awg. Is there something not right with this plan? I made a little diagram of what I'm thinking. thanks for any help you can give
