New Discovery
Discussion in 'All Things Boats & Boating' started by wardd, Sep 15, 2010.
  1. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    I've discovered this substance that if your put a boat in it will make it float
    In short it will float your boat.
    I call it Whatever.
  2. Doug Lord
    Doug Lord Flight Ready
    Floating my boat
    So you're saying "Whatever will float your boat". I'm afraid that you have a serious problem: producing enough whatever to float your boat would probably be awfully expensive-and there is the nagging problem of all that water that would have to be moved, I guess.
    While its great to see such creativity and to witness new discoveries I'm afraid that you may be, shall we say, all wet.....(at least on earth for the time being)
  3. peter radclyffe
    Likes: 64, Points: 58, Legacy Rep: 680
    peter radclyffe Senior Member
    Wardd, you have solved all the worlds problems, how can we ever repay you, let me guess ?
  4. wardd
    wardd Senior Member
    I have whatever now I need a boat to float in it
  5. SamSam
    SamSam Senior Member
    Is "Whatever" the Walmart knock off brand of "Rising Tide"?
  6. wardd
    wardd Senior Member
    No rising tide floats all boats where as whatever will float your boat but is much cheaper
  7. apex1
    apex1 Guest
    That sounds like a patent infringement Mate!
    I tested "whatever" already in the early 1960ies with astounding success. Though I named it "Dihydrogen monoxide"
    Although I was very pleased with the stuff and enjoyed years of relaxed sailing in it, I later gave up due to some severe risks, I became aware of.
    These dangers of dihydrogen monoxide include:
    * Also called ‘hydroxyl acid’, the substance is a major component of acid rain;
    * Contributes to soil erosion;
    * Contributes to the greenhouse effect;
    * Accelerates corrosion and breakdown of electrical equipment;
    * Excessive ingestion may cause various unpleasant effects;
    * Prolonged contact with its solid form results in severe tissue damage;
    * Inhalation, even in small quantities, may cause death;
    * Its gaseous form may cause severe burns;
    * It has been found in the tumors of terminal cancer patients;
    * Withdrawal by those addicted to the substance causes certain death within 168 hours.
    Nevertheless, governments and corporations continue using it widely, heedless of its grave dangers.
    I therefore will skimp on any possible lawsuits against you, and grant permission of using and even renaming dihydrogen monoxide to whatever.
    Regards
    Richard
  8. wardd
    wardd Senior Member
    of course there were dangers, you didn't use another of my discoveries, Stop Leak, your hull was all leaky
  9. Petros
    Petros Senior Member
    Too bad it can not be patented, whatever is "prior art".
    FYI, you did not discover it. I think dates back to the beginning of when humans started messing about with boats. The ancient whatever can no longer be patented. But that does not stop anyone from using it now of course.
    Whatever, have fun with it.
  10. wardd
    wardd Senior Member
    whatever isn't all fun, it can be used commercially by cargo ships and even war ships
    to meet military requirements costs more
    just adding color to hide subs is expensive
  11. Doug Lord
    What, a whatever pond? Or Ocean? Whatever for? I'm not sure they'll like this in Nah'leans....
  12. SamSam
    Is this a part of the house training pet product "Stop Leak with Don't Dump" empire?
  13. Petros
    What do you mean pets? Sell it to the elderly and you can charge much more for it.
  14. CatBuilder
    CatBuilder Previous Member
    Is this Questor??;)
  15. BostonSailBoat
    BostonSailBoat New Member
    this thread makes me laugh :)
