sandhammaren05
Senior Member
- Joined
- May 7, 2009
- Messages
- 436
- Reaction score
- 35
- Location
- Texas & Austria
Here's a follow-up on my posts of several years ago.
I've just completed the ms for a new book (with lots of color photos of fast boats, and lots of equations) that covers props and tunnels from the standpoint of physics/hydrodynamics. I'm looking for a publisher.
Here are the title and the table of contents:
The Physics of Surface-Piercing Propellers and High Performance Boats
Speed through drag reduction
Joseph L. McCauley
Physics Dept.
Univ. of Houston
Houston, Tx. 77204
outboard_services@mccauleyandson.com
Table of contents
1.Hydrodynamics
1.1 Basic equations of fluid flow
1.2 ‘Dry water’
1.3 The Reynolds number and scaling
1.4 Vorticity, the boundary layer, and the wake
2. Propeller efficiency
2.1 Propeller approximated as an ‘actuating disc’
2.2 A propeller blade creates a helical wake
2.3 Scaling of thrust, torque, power, and efficiency
2.4 Mechanical efficiency of propellers
3. Optimizing raceboat performance
3.1 Optimizing acceleration and top speed
3.2 Scaling of propeller diameter with power and RPM
4. Form drag, waves, and skin friction
4.1 Dynamics of vorticity and vortices
4.2 Boundary layer separation and eddy creation
4.3 Scaling of speed with power and weight
5. Theory of lift and drag on a hydrofoil
5.1 How an airplane flies, how a propeller propels
5.2 Theory of lift and drag on a hydrofoil
5.3 Propeller blades as rotating hydrofoils
6. High performance boat set up
6.1 Fast boat bottoms and set-up
6.2 Planing speed
6.3 Camber, center of pressure and stability of a tunnel
6.4 Rake and prop riding
6.5 Lubrication, tractor and overdrive gearcases, world speed records, and emissions
The attached photo shows my son (he and the next two behind him are running my props) at the start of heat 3 in the SST45 Class national championships last Sept., 17 tunnels on a 30 sec. course.
Joseph L. McCauley
Physics Dept.
Univ. of Houston
Houston, Tx. 77204
Table of contents
1.Hydrodynamics
1.2 ‘Dry water’
6.2 Planing speed
