new boatbuilder
Discussion in 'Wooden Boat Building and Restoration' started by sean-nós, May 14, 2010.
  1. Tahoerover
    Tahoerover Junior Member
    Why a four blade? Use a three or even a two blade.
  2. sean-nós
    Likes: 30, Points: 0, Legacy Rep: 392
    sean-nós Senior Member
    It came with the donor boat a 16 foot ski boat so if it worked for that it should work for mine plus I don't want to spend more money if I don't need to, I won't be racing this boat just messing about and spreading the sound of a V8 :D
  3. BATAAN
    Likes: 101, Points: 0, Legacy Rep: 1151
    BATAAN Senior Member
    Wow that looks like fun.
  4. sean-nós
    Just a quick update, the engine has had it's first test run :D
    And as we had a few good days of weather I went ahead with the fiberglassing just doing one side at a time I was able to give it 4 coats of resin with a 3 hour gap between each one.
    I kept all the overlaps below what I think will be the waterline where it will be painted. now let the sanding begin :rolleyes:
  5. Ike
    Likes: 524, Points: 113, Legacy Rep: 1669
    Ike Senior Member
    Wow. Looks good. Keep posting.
  6. hoytedow
    You are making great progress.
  7. sean-nós
    First coat of primer I will sand this down with 600 paper and do two more coats and sand again.
    And first coat of paint "roll and tipped" I will do another 3 or 4 coats with a light sanding in between then on the last coat I will sand it with 800, 1000, 1500, 2000, wet and then rubbing compound.
  8. sean-nós
    I had to make up a new strut suit my angle.
    Just have to sink it a bit more and fiberglass the base and the prop tube that will hold the stuffing box.
    I always knew it would be tight to fit the rudder but I just might get away with it using a plate on it also I think I will recess it into the hull so it sits flush.
  9. TeakGuyFL
    TeakGuyFL Junior Member
    Paint looks KILLER! Nice Job!
  10. Collin
    Likes: 6, Points: 0, Legacy Rep: 51
    Collin Senior Member
    Yes, it looks very well done.
  11. sean-nós
    Cheers guy's I still have to do another 3-4 coats after I fiberglass in the prop tube strut base and rudder hole then sand it with 1000-1500 wet paper then rubbing compound and wax to get a gelcoat look finish.:D
  12. sean-nós
    I sold my donor boat shell :D so started to rebuild the trailer with new bolts,bearings,brakes,cables,tow hitch and so on won't be long now till the flip:D
  13. michael pierzga
    michael pierzga Senior Member
    Hmmm....I Never found the need to use 600 with paint ? Normally course paper...220 for primer, then 320 to 400 for finish coats. Working in the proper temp with the proper viscosity paint gives glasslike roll and brush . Carefull you dont develope an adhesion problem with such fine paper.
  14. sean-nós
    Your right my mistake it was 200 paper on the primer :D
  15. michael pierzga
    Ahh...sounds better.
    Occasionally I use very fine paper or scotch bright pads on touch up work. Last week I removed a piece of masking tape from a previous small touch up and the finish coat came off with the tape. Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr..............................................
    Beware of very fine paper,the tooth may not be sufficient .
