New Aftmast Rig
brian eiland
Senior Member
Joined
Jun 3, 2002
Posts
5,658
Reaction score
333
Location
St Augustine Fl, Thailand
I've modified the new aftmast rig
1) less rake,
2) mizzen attached to older bare mast,
3) twin backstays to the masthead & the hounds.
Very nice model.
It's a little picky, I know, but I'm concerned about the sheet angle on the inner staysail. Pulling down, with no aftwards component, I'm picturing a tight leach, with little foot tension causing a poor foil shape.
-Will
That model was actually built to represent my previous 10 degree mast rake design, so there are a number of small discrepancies like the extra long gaps at the bottoms of those 2 forestays, etc. I had to limit the exactness I could change, particularly with my still stiff healing wrist, and some eyesight problems I am now experiencing. Wanted to get the general plan displayed for a number of naysayers out there.
PS: another change in the final design would likely involve a small extension to the sterns to further take those anchor points of the backstays a bit further aft, and maybe a slightly smaller mizzen sail.
Good on you for noticing :cool:
Why Did I Choose that Double Headsail Arrangement?
1) Have a look at this paper presented by aerodynamist Arvel Gentry:
More on the Slot Effect
https://oceansailing.meder.hu/wp-con...lot-Effect.pdf
2) Have a look at this paper presented by Paul Bogataj of North Sails:
How Sails Work
In both papers they talk about the interaction of a combination of 2 sails, and how the leading sail is greatly benefited by the trailing sail nearby,..
SAILS IN COMBINATION
Each sail by itself is much simpler than the combination of a foresail and mainsail as in the sloop rig. The sails are operating so close to each other that they both have significant interaction with the other. The most interesting feature of this is that the two sails together produce more force to pull the boat than the sum of their forces if they were each alone.
The mainsail behind the mast prevents the typical drag creating ”vortex street” from forming. Instead, flow is accelerated rapidly in front of the mast, resulting in a suction force towards the bow. This suction can create a positive drive up to 5% of the total drive of the sails. Traditionally, the mast has been considered as a nuisance only, creating air drag. It would seem to be more appropriate to think of the mast as part of the mainsail profile instead.
Most of the positive drive comes from the topmast above the hounds. In this part of the rig, wind is more twisted to the side, partly because there is no jib or genoa interfering, and partly because of the head vortices shed by the sails. Thus, for a 9/10-rigged, modern boat equipped with a jib rather than a genoa, the mast drive can be negligible or it can be even negative, real drag.
In case of a genoa equipped boat, the lower part of the mast lies in a more beneficial airflow than for a jib equipped boat. Aft rake contributes to the intensity of the vortex behind the mast. This could be one reason for the benefits of raking the mast aft in fractionally rigged boats.
Note that in aerodynamic terms, the mast does produce drag, as the aerodynamic drag is defined in the direction of the apparent wind. But in hydrodynamic terms, where the drag is oriented against the direction of the motion of the boat, the drag is often negative.
This sounds like BS to me,...perhaps a result of these new technics utilized to define the flows,...
In the last few years, advances in CFD (Computer Fluid Dynamics) and FSI (Fluid Structure Interaction) have changed the way we perceive sail aerodynamics. Old beliefs are proven wrong and new features found
I don't think there is ANY fixed mast tube (or even rotating mast) that contributes POSITIVE DRIVE FORCE to the vessel ! Perhaps a wing mast could contribute positive drive force.
And this particular quote really sounds like BS,...that bare mast up there with no sails in front is going to give positive drive,...I don't think so !
I rather think that portion of the mast above the hounds could be providing a positive slot effect for a masthead genoa sail.
When it comes to BS, Brian, you are the master at spreading it. For someone who has spent years fantasising about how great his rig will be but somehow can’t get his act together enough to even build a test rig to throw such accusations at someone who knows far more about the field than you do is disgusting.
You do know that on this forum Tom Speer, an expert who you quote when it suits the BS you push, said quite clearly that a fixed mast tube DOES provide positive drive force? Are you claiming that Tom was full of BS too?
Can you show me exactly where he says that very thing? I want to see his exact wording !
Here in the Sail Aerodynamics thread page 24, in reply a comment (post 358)” by the valued and expert Mikko Brummer who you so foully accuse of writing “BS”. In his post 359, Tom “agree(d) completely” with Mikko’s comments that "the mast is not just a drag-device but contributes significantly to the driving force of the sails. In a recent CFD study on Star sails, the mainsail drive was 10,2 kgf, jib drive 6,7 kgf and the mast drive 1,2 kgf (that's in the positive, forward direction for the mast as well). "
Tom remarked in his post
I agree completely. The leading edge suction on the mast is a significant contributor to the drive of the whole sail rig.
I quoted it to you on Cruiser Forum ten days ago. You ignored it then. You could have used the search engine on the quote, but with your usual approach you ducked the issue and kept on spamming BS. And if you think I’m being rude then you shouldn’t abuse people like Mikko as you did.
"Mikko Brummer who you so foully accuse of writing “BS”. In his post 359, Tom “agree(d) completely” with Mikko’s comments that "the mast is not just a drag-device but contributes significantly to the driving force of the sails. In a recent CFD study on Star sails, the mainsail drive was 10,2 kgf, jib drive 6,7 kgf and the mast drive 1,2 kgf (that's in the positive, forward direction for the mast as well). "
I obtain a similar result with a simple yet robust (Ludwig Prandtl and Max Michael Munk) analysis
B: "Baja", Low pressure, Suction
A: "Alta", High pressure
D: Drag
Tom Speer
"I agree completely. The leading edge suction on the mast is a significant contributor to the drive of the whole sail rig"
Exactly
In the study of this spruce wood mast (15 x 10 x 700 cm)
AWA: 30°
AWS: 16.87 knots
Lift: 67 Newtons
Drag: 20.8 Newtons
Drive Force: 15.69 Newtons
How Sails Work
This issue involves many numerical nuances:
1) A mast alone
2) The shape of the mast
3) A mast with a mainsail
4) A mast with a mainsail and a jib
5) Different angles of attack
However, while there are nuances to consider when it comes to quantification ...
... it is an entirely different matter if someone cannot even distinguish two from three -if they cannot even count the number of sails appearing on their own model...
SailBoat 2 Sails interaction
UpWash and DownWash
Lift Coefficient (CL)
Ludwig Prandtl, Max Michael Munk and Dr. Ulrich Remmlinger
Notice what TSpeer says,...contributes to the drive of the whole sail rig.
He did NOT say contributes to the forward drive of the mast itself !!
...only Mikko hinted at that very small amount.
Mikko's observations about the individual contributors was obtained with recent CFD studies,...computer wizardry that he admits in other postings can be questionable, particularly on his computer which he was having problems with at the time
I wish TSpeer was still on the forums, and might clear up this question.
PS: Even if there was someway to could find a way to contribute some very small driving force to the mast section itself,.. I'll bet the drag force of that same mast section would far offset the drive amount.
Imagine driving down the road while holding a mast section out the window, Does anyone think that they could reduce the drag of unit to zero, or even a negative,....REGARDLESS of the multitude of orientations you might try out.
