New 25M Motoryacht design any takers?
Discussion in 'Boat Design' started by raffshore, Nov 28, 2018.
  1. raffshore
    Likes: 1, Points: 8, Legacy Rep: 17
    raffshore Junior Member
    Just wanted to share my passe time and passion.
    Aluminium build
    Choice of displacement, semi planing or planing hull
    Currently working on the interior
    Drawings in Sketchup and rendering in Keyshot...
  2. Squidly-Diddly
    Likes: 187, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    Stairs to Nowhere under diving board?
    I'd lose the 45' angle on rear PWC storage hatch, extend it back and drop 90' vertical. That way the outside dining table deck gets bigger, too. Have the rear storage hatch open from 90' to level 0' for walking headroom shade/overhead lights of swim deck, and also extension of dining area.
    Run two horizontal poles above fly-bridge to carry sunshade or even enclosed fabric.
  3. raffshore
    Sounds like a good idea.
    not a diving board but passerelle :)
    Poles good idea rear and front
    thanks for the input
  4. DCockey
    Likes: 678, Points: 113, Legacy Rep: 1485
    DCockey Participant
    Any naval architecture / engineering, or is this about appearance only?
  5. tz3dcom
    Likes: 8, Points: 28, Legacy Rep: 22
    tz3dcom 3D
    I also feel the flybrigde too short ,a yacht in this size should has a dinghy deck to carry the dinghy.
  6. upchurchmr
    upchurchmr Senior Member
    Illustration I'd bet.
    If you have a choice of semi planing or planning means its just a picture.
    Pammie and kerosene like this.
  7. raffshore
    It has a 30 square meter garage for 2 jetski's and a 5m rib. I think it doesn't look clean with a dinghy on the deck but that is personal
    Why is that? everything under the water line can be changed so easily. Included the analysis from volvo penta on a 15m I did for a customer and for this one I used the same hull.
  8. raffshore
    deck layouts
  9. tz3dcom
    tz3dcom 3D
    Do you have a lowdeck plan with engine room and dinghy store layout ? I also find out the hull without any portlight so your boat without the accommodation in lower deck ?
  10. tz3dcom
    tz3dcom 3D
    the engine room under the dinghy room ? not sure if it's enough to arrange in height.
  11. raffshore
    Yes dinghy room is at the same level as the under deck.
    Portlight I still have to be decided yes
    I am sure it has, when I start drawing I always start by setting the heights to be sure all fits. I have everywhere 2100 mm head room in this one and enough room for engines
  12. raffshore
    measurements
  13. raffshore
    TZ3D you make nice designs, if it would ever become a project I would contact you for the interior
  14. tz3dcom
    tz3dcom 3D
    Ok , You are welcom ,thanks
  15. kapnD
    Likes: 545, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Hello, earth calling!
