NeverWet
Discussion in 'All Things Boats & Boating' started by SaltOntheBrain, Dec 29, 2013.
  1. SaltOntheBrain
    Likes: 7, Points: 18, Legacy Rep: 87
    SaltOntheBrain Senior Member
    Anybody get the bright idea to try Rustoleum's NeverWet on a boat hull? Does it make a difference in performance at planning or displacement speeds?
    LF
    As far as I know, it is about the same as Thompson Water Seal. I tried it and it made me lose speed. It ended up with a layer of goop after a day in salt water.
  3. jonr
    jonr Senior Member
    It has a slightly rough and not too durable surface - I have to say that I haven't really found a good use for it.
  4. PAR
    Thompsons and NeverWet aren't the same chemically. NeverWet will wear off quickly, while Thompsoms will last a wee bit longer. Thompsons will contaminate the surface with wax that is difficult to remove if you plan on painting the surface at some point.
  5. SaltOntheBrain
    Thanks for saving me the trouble, gonzo. It looked pretty interesting in their videos.
  6. Stumble
    Stumble Senior Member
    Neverwet says it needs to be constantly exposed to air to work. So it may be worth the experiment on a planning hull, but on a sailboat it would fail quickly.
