NEED WIRING SCEMATICS for 76 IMP shifter
Discussion in 'OnBoard Electronics & Controls' started by VKRUE, Apr 24, 2006.
  1. VKRUE
    Likes: 12, Points: 28, Legacy Rep: 64
    VKRUE Just another boat lover
    A friend of a friend has asked me to get his 76 IMP AZTEC together and running for the summer. Has not been used for some years. Someone took it to a "less than reputable" marine mechanic only to get the boat back with same problems (electrical) and the shifter completely disassembled and scattered about the boat. Everything else about the craft and it's engine seems to be in good working order.
    I've got the majority of the electrical issues taken care of but, now I have to reassemble the shifter and it's wiring.
    This boat has a 235 omc.
    There are 5 or 6 wires leading to the shifter of which one is a power lead from the ignition (as far as I've been able to determine).
    Can any one tell me how to correctly hook these up.
    Thanks in advance for all comments. :) :) :)
    VKRUE
    Likes: 1,615, Points: 123, Legacy Rep: 2031
    Is there a trim switch on the shifter?
  3. VKRUE
    Trim Switch
    Hi Gonzo,
    No, the trim switch is on the dash and works properly.
    VKRUE
  4. gonzo
    Red- power from the battery
    Purple- to the ignition
    yellow/red tracer- starter
  5. VKRUE
    Color Coded Wires ?
    Thanks again Gonzo, but my wires are colored as follows
    one red wire = power / which splits off as a jumper for a second terminal
    two white wires
    one green and
    one blue
    The terminals in the shifter appear to be actual switches.
    Was talking to a guy at work today who suggested that the blue & green wires each lead to separate solinoids (one for forward, the other for reverse) in the out drive. The red wire with the jumper powers each solinoid and the two white wires possibly for a neutral switch or sensor.
    Wish I had an actual picture of the terminals / switchs at the shifter but have included a rough scetch ( am a poor artist).
    Could the forward switch be the "REVERSE" and the aft switch be the "forward" leaving the center switch to be the neutral sensor ?
    VKRUE
  6. gonzo
    Can you describe the setup in more detail? Is the ignition switch on the shifter?
    The green wire is the trim down , the blue wire is the trim up.
  7. VKRUE
    Trim Switch
    Once again, no.
    The trim & lift are located on the dash and both work fine.
    The shifter appears to only control the forward & reverse as well as the throttle.
    Understand that your trying :) :) :)
    VKRUE
  8. gonzo
    The only thing you really need in the shifter is the neutral safety switch. It interrupts the circuit in the yellow/red tracer wire so it won't start unless the shifter is in neutral. I don't know what the other are for.
  9. VKRUE
    Many Thanks
    Thanks Gonzo, I've got the thing running using the layout as discribed in my not so artsy scetch. Don't claim to be a mechanic, so I don't have as much knowledge about how these things work as others...
    No scematics need now.
    Thanks again anyway... :) :) :)
    VKRUE
  1. Velsia
  2. sdowney717
  3. Charlyipad
  4. Jorda
  5. kapnD
  6. the brain
  7. snowbirder
  8. Mik the stick
  9. cruiserpete
  10. Manie B
