Note: This feature may not be available in some browsers.
Film faced plywood. Fenol film on the surface. At least epoxy doesn't stick to it..What do you mean by "surfaced" I am trying to save some effort by using something flat and glossy to simply spray PVA over to make the panel from...
I’ve seen glass stick up on several occasions but also seen it work ok. I prefer full gloss melamine/formica. Seems to take wax better, easier to handle and store and much cheaper for bigger sheets.
You can also cut it and glue it and fillet it to make more complex shapes.
That is good information for potential future projects even, as it could be used as a temporary mold
Maybe a little off topic, For more complex or compound curves, would I be better off using thin strips, seems like wood panels or fiberglass panels may only have so much bend to them... ?
This is true, and usually takes the form of applying wax coats on one after the other without adequate drying time between coats.It can stick to glass, but only if you don't prep the surface correctly, as in, not following the directions for that exact mold release product as written on the container.
I have not experimented with compounding, my reference to complex shapes and filleting refers only to making moulds in flat planes as in internal furniture or bulkheads.
I have wondered what could be done with contour foam bagged onto a panel and then tortured without the internal skin but have never tried it.
I suspect the main limitation would be the grp skin rather than any particular core materialI suspect you would get reasonable results with quite gentle curves but for tighter curves it might be better with honeycomb or even over-expanded honeycomb.The downside is the higher probability of later delamination as a result of the much smaller bonding area.
