Hello all.
I am in the process of rebuilding a Mowdy S10 scooter boat (5' wide by 10' long) and have found the need to remove the floor to replace the foam and transom.
The original floor from the manufacturer was 4mm Coremat with a single layer of fiberglass on the bottom and 2-3 layers on the top. I cannot tell exactly if the FG was CSM or a biaxial product. I can see through whatever product they used and can clearly make out the perforations in the Coremat.
The floor is 60” wide with two 12” wide foam/fiberglass stringers so no section of the flooring will be spanning greater than 12” side to side. I have not removed the floor yet so I cannot determine if there are any bulkheads. My guess is there is not.
I have attached a picture I found of the same model boat with the floor removed for reference.
My quandary is what do I replace the floor with.
The options I have come up with so far are some form of Core-Cell encapsulated in a single layer of 1708 on the bottom and 2 layers on top.
The second option is a similar composition using balsa with the same FG plan. I prefer no wood in this boat, but if balsa is the best option I will seriously consider it.
A third option would be to reproduce exactly what the OEM did.
I will be using epoxy in lieu of polyester resin which ever floor is built.
The best thing about this project is that it uses so little raw materials that the budget allows pretty much any material available and still be affordable.
I would love to hear from others that might have input on what they would do.
Thanks,
Rob
Thanks,
Rob
