GUSRENTIT
Junior Member
- Joined
- Dec 20, 2020
- Posts
- 11
- Reaction score
- Location
- Pueblo, Colorado, USA
Howdy, I'm the new guy, and very unfamiliar with Cat designs/engineering. So I will be working on a Cat that I got years ago, for free. Its a AMC SeaMoth, 15' sailboat,,, without any sail equipment, but that's ok, as I want to make several modifications, and make a motor Cat. Not knowing the how and why of hull design, does not mean that I don't know what or how to do it. Granted this is a small Cat, not something that you guys tend to talk about, BUT marine theory, should apply to almost any size. I need some basic knowledge, and some not so basic info.
OK, 1) Why do I keep hearing that sail boats don't make good motor boats, ( most sail boats have motors ), most sail boats are displacement hulls, yes,, not all...
2) On Cats and most other boats have the Banana hull curve, fore/aft, mainly it sweeps up at the aft, what does that do,,, what is it for ?
3) What would happen if I took some of that rocker shape out of it by adding/building up the bottom of the aft hull, and adding about a foot to the length of the hull. I realize that it would increase buoyancy aft and make it a bit more nose down, but then again, the added weight of a motor and gear, would lower it back down and increase the water line, and add a bit of drag.
Thanks in advance,
Gus
Thanks in advance,
Gus
