the brain
Senior Member
- Joined
- Sep 3, 2016
- Posts
- 440
- Reaction score
- Location
- Alabama, home of college football champions
Need advise on RPMs shooting up like 500RPMs w/ new engine
This is a repower. Here’s the vessel at rest more on it lower down. cav plate is like 2" underwater remember this is a work in progress while being used Image image
1st shakedown run seamed normal an yes I had it floored on all these runs, I usually don't cruise much it's WOT as much as possible except for speed zones video
https://www.youtube.com/shorts/ks2P76MutxY
2nd shakedown run wasn’t a run at all just cranked ideled then water alarm came on so I turned her off. There was a little water pump discharge seam like the weak stream I have w/ the garden hose in backyard. video.
https://youtube.com/shorts/OBEBKFpmw2A
3rd shakedown run seamed normal then RPM Shoot-up to 6K RPM but then lowered itself to normal 5500RPM video
https://youtube.com/shorts/mm99-VALy_U
4th shake run she shootup the RPMs
https://www.youtube.com/shorts/VoOHohqGcyo
5th Shakedown run seamed like things where improving a bit then the on oil alarm came on. I have a half filled oil reservoir.plan to keep fullish from now on.
6th shakedown run again RPM shotup to just under 6K so I pulled back on throttle then oil alarm again.
https://www.youtube.com/shorts/p55STnpueHY
7th run just putting over idel oil alarm again next crankup she was in limp mode won’t allow any increase in throttle. So limped back to dock.
https://youtube.com/shorts/p55STnpueHY
1977 24’ Starcraft Chieftain converted to outboard w/ armstronge bracket. Hull weight is around 1900LBs
Plus 2 batteries, 2 anchors,gear ect conservative estimated weight 2300LB plus 420LB engine so not real heavy for her size.
Same prop from previous engine 04 JohnsonBRP 175HP. Same engine height. previous engine height could be a tad lower All of these short runs where no trim up.
I think trim up will increase RPMs even more?
previous engine felt a tad stronger. But then again I haven’t been cruising for over 5 years so maybe I forgot how well previous preformed.
What I distinctively remember w/ PE she jumped up on plane instantly. but back in the good ole days I would go straight to WOT unlike in these initial shakedowns
The new 012 ETEC 175HP G1 only 170 hours seams to be running OK just feels a bit different. Maybe she needs a tune up.
What I did was motor to middle of lake then did the WOT runs to confirm I had the correct prop.I didn’t venture far from the dock.
Not sure what to think about he RPMs shootting upto 6K an some runs a tad under 6K another run shot up then normalized to the 5500RPM which I believe is the desired RPM.please advise.thanks
initialy I wanted to use the tripod that holds the camera so I could video the engine at idel an at top speed to verifiy the correct engine height but couldn't find the tripod so I'll order a new one an post up videos specifically of engine height
t
t
