Need advice on hull
Discussion in 'Boat Design' started by fbeytell, Nov 10, 2006.
  1. alidesigner
    Likes: 6, Points: 0, Legacy Rep: 93
    alidesigner Senior Member
    As strange as it may sound the smaller the boat is the harder it is to design. This is because they are so sensitive to weight. So if you are going to design it yourself then spend a lot of time getting your weight estimate right.
    For good ride you want high dearise and for stability you want low dearise so your final design will be a compromise between the two. There's no magic number as it all depends on weight and boat layout.
    I would suggest looking at manufacturers web sites. Many of them publish technical specs that would be a good starting point.
    Also do a search on kit boat designs. I have seen them as low as $400. If you can find a similar design it would be money well spent.
  2. rayaldridge
    Likes: 26, Points: 0, Legacy Rep: 322
    rayaldridge Senior Member
    I'm sure that's true, but the great advantage of starting small is that if it's a disaster, it's a small disaster. Of course, the way to properly distribute weight in a small open boat is to get aboard and then move around until you like the way the boat sits.
    Also, there have been so many small boat designs, derived from working boats and optimized over the centuries, that you have a vast array of good examples to steal ideas from. The downside, I suppose, is that you're unlikely to come up with anything that's genuinely new as well as genuinely good.
  3. Thin water
    Likes: 2, Points: 0, Legacy Rep: 26
    Thin water Senior Member
    Please post progress updates. As your plans near completion, many on this site (Not me, I only build others designs, for now...) will point out major flaws and comprimises you will have made. With your skill level in building things you will be able to make a good boat, if the design is good.
    Go for it!
  4. Pericles
    Likes: 135, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
