Need a non-adhesive sealant.
Discussion in 'Materials' started by fallguy, Aug 22, 2020.
  1. Blueknarr
    Likes: 228, Points: 63
    Blueknarr Senior Member
    You are probably over think this. The gap between the tubes is small enough that whatever sealant used won't be able to be pushed in far. An Alfa knife will cut through it easily enough.
    fallguy likes this.
  2. fallguy
    Likes: 732, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    For sure a bit true. Gonna go google alfa knife.
  3. fallguy
    My apologies for getting snippy. I went down for the count yesterday. Not the heart, but back problems. 1894C0BC-63B7-42F9-AAF6-F740E08E7502.jpeg
  4. hoytedow
    Likes: 349, Points: 93, Legacy Rep: 2489
    hoytedow Helmsman
    Get well soon.
  5. Blueknarr
    Yes do get well soon.
    My bad it's OLFA not Alfa.
    Thin retractable snap away blades.
  6. kapnD
    Likes: 118, Points: 43, Legacy Rep: 40
    kapnD Senior Member
    Use a backer rod or some similar flexible foam filler to limit the depth of the caulk, topped off with a thin, even bead of ADHESIVE caulk, 5200 or whatever.
    As long as the caulking bead is kept thin, it can be easily cut away in the future if need be.
    fallguy likes this.
  7. fallguy
    I think Mr . E is going to get the W here. I ordered plasticine this week and the only question is will it stay if beat by waves? I have decided the best way is to bead around this thing, rather than insert much. The silencing is too close to the edges to get much depth into the seam.
  8. fallguy
    Ugh. Plasticine says it is made from calcium salts. I have been researching its water resistance.
  9. DogCavalry
    Likes: 644, Points: 113
    DogCavalry I aim to misbehave.
    Toiletbowl wax is looking attractive... there's a sentence I never thought I'd write.
    BlueBell likes this.
